Fuel management - Road Glide Forums
post #1 of 16 (permalink) Old 03-01-2013, 05:28 PM Thread Starter
Talking Fuel management
I'm a handlebar guru but am a loss for fuel management.
Just picked up a 13 Roadglide. Going with 570 cams and freedom performance exhaust. Any suggestions?
John Pollock
wild1techguy is offline
post #2 of 16 (permalink) Old 03-01-2013, 05:51 PM
Triplej's Avatar
Power Vision, give Jamie at Fuel Moto a holler, can't go wrong.......
And welcome to the Tank from Texas.
Triplej is offline
post #3 of 16 (permalink) Old 03-01-2013, 06:33 PM
Speedie's Avatar
Ditto on the Power Vision. Best product out there.
2015 Road Glide Special
Detachable Trunk : Detachable Passenger Back Rest
Rinehart Exhaust : De-Cat Headers : J&M 330W Rokker Amp and Speakers
Speedie is offline
post #4 of 16 (permalink) Old 03-01-2013, 08:15 PM
Re: Fuel management
You might want to look at the TMax also.
post #5 of 16 (permalink) Old 03-04-2013, 12:16 PM Thread Starter
Thumbs up Fuel
Thank you for the feedback. I will look into both systems.
John Pollock
post #6 of 16 (permalink) Old 03-04-2013, 06:10 PM
4getNo1's Avatar
Those are the ones I'm considering too. I can't decide whether or not I want to tinker with stuff myself sometimes (Power Vision) or simply forget about that stuff, the gizmo is doing it's thing all by itself (T-Max).
2013 FLTRX, Candy Orange
4getNo1 is offline
post #7 of 16 (permalink) Old 03-04-2013, 09:28 PM
Hullhorr's Avatar
You can actually do that with both. There is an auto tune module you can purchase separately for the Power Vision. With the Thundermax you can make changes with your laptop plugged in. Although with the Power Vision you can make adjustments while riding. Personally I went the Thundermax route. Set it and forget it. I don't think you can go wrong with either one though.
2009 FLTR MOP
Hullhorr is offline
post #8 of 16 (permalink) Old 03-05-2013, 12:43 AM
4getNo1's Avatar
Thanks Hullhorr. I wasn't getting the full picture on how the auto tune was incorporated with the Power Vision (an optional separate module).
I suspect that here in FL, I won't really need that since about the only thing I can think of changing after the main elements are established would be A/F ratios due to some serious elevation changes. Of course, I'm such an old guy the last time I personally tuned my HD was when we used points, condensers, and jets too.
4getNo1 is offline
post #9 of 16 (permalink) Old 03-05-2013, 12:56 AM
Bluchevypick's Avatar
Thundermaxx Here as well
Bluchevypick is offline
post #10 of 16 (permalink) Old 03-05-2013, 05:20 AM
PFWiz's Avatar
Re: Fuel management
My Tmax works great. It is really pretty easy to manually adjust.
Installed a set of Tman 555 tq cams this winter, but no dyno for me! Loaded a new map and the Tmax will do the rest.
PFWiz is offline
Dyno tuner in Alabama - and what fuel management system justaguy ECM/Fuel Management systems 2 06-24-2013 10:23 AM
Cobra Fi2000 closed loop fuel management bt99ultra ECM/Fuel Management systems 16 02-04-2013 09:50 AM
Need to know about Fuel Management Devices Still Grumpy ECM/Fuel Management systems 11 11-02-2012 03:46 PM
fuel management options Tatude ECM/Fuel Management systems 12 09-22-2011 06:39 PM
Better options for fuel management? bvanlente ECM/Fuel Management systems 6 08-10-2011 08:03 PM
