Micro EFI Tuner or Fuelpak enough? - Road Glide Forums
post #1 of 5 (permalink) Old 03-06-2013, 08:31 AM Thread Starter
Deadstroke's Avatar
Friend of mine has a 2013 RG - Took out the Cats and drilled out the exhaust and put on a hi-flow.
Question is he bought the V&H fuelpak but I am curious if that is enough or if Micro EFI Tuner would be a better idea..
Thanks
Deadstroke is offline
post #2 of 5 (permalink) Old 03-06-2013, 08:46 AM
4getNo1's Avatar
Thanks
ETA - Sorry Deadstroke but I DELETED MY POST. I'm honestly not positive about de-catting along with whether or not slip-ons were changed and don't want to mislead you. I'm pretty sure he's fine though, especially if he received a map from V&H that corresponds to what he's done.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #3 of 5 (permalink) Old 03-06-2013, 08:57 AM
Garemlin's Avatar
Fuelpak is ok if you are running V&H pipes and are happy with what they give you.
The FM Micro EFI Tuner are way more tune-able. They will get you a map for pretty much any pipes. The Micro Tuner can also store up to three maps. So you can keep a stock one on board if needed. One big thing is the Micro Tuner can be dyno tuned and tweaked if you choose. Need something tweaked with the FP and you have to call V&H and hope for the best with the combination of numbers they send you.
Keep in mind both of these choices are if you plan on doing nothing more than a Stage 1. If you plan on or think you might do other upgrades from as simple as a cam swap on up you may want to look at other options.
Garemlin is online now
post #4 of 5 (permalink) Old 03-06-2013, 11:36 AM
Xaran's Avatar
Thanks
For about the same $ go Fuel Moto Micro Tuner hands down.
FM will give you outstanding customer support and double the warranty. The Micro Tuner can alter both the fuel and timing the Fuel pak only adds or removes fuel
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #5 of 5 (permalink) Old 03-06-2013, 01:17 PM
Garemlin's Avatar
I will echo everything but I do need to correct one thing you said. The Micro Tuner does not allow any adjustments to the timing.
Fuel Moto Micro EFI Tuner SteveH Parts for Sale 0 10-17-2016 12:51 PM
Fuel Moto micro EFI tuner crapped out SurlyBoy ECM/Fuel Management systems 8 08-24-2015 12:41 AM
$199 2014 FLH Fuel Moto Micro EFI tuner now available fuelmoto Fuel Moto 0 11-11-2013 12:52 PM
Fuel Moto Micro EFI Tuner install and review Garemlin ECM/Fuel Management systems 21 06-28-2013 04:50 PM
Fuel Moto Micro EFI Tuner hamer007 ECM/Fuel Management systems 3 12-14-2012 08:29 AM
