Power Vision Upgrade - Road Glide Forums
post #1 of 3 (permalink) Old 02-17-2017, 08:34 AM Thread Starter
Hdclw99's Avatar
I have a 2015 RGS that I installed a PV, Jackpot header and a Stage 1 breather. I just added cams, lifters and adjustable pushrods. When I installed the header and other things, I used the narrow band 02 sensors. Will I be able to install the wide band 02 sensors, now, for better tuning? Or will I have to change the Tuner that uses the wide band sensors?
Thanks
Hdclw99 is offline
post #2 of 3 (permalink) Old 02-17-2017, 09:33 AM
slowglide2989's Avatar
Thanks
The Target Tune is a piggy back module that works with the existing PV you have. Order your target tune and immediately send email request for base map. You should receive your tune by the time your Target Tune arrives in the mail.
slowglide2989 is offline
post #3 of 3 (permalink) Old 02-17-2017, 10:03 AM
Wide band O2 sensors are 18mm and the stock O2 sensors in your bike are 12mm so if your exhaust doesn't have the 18mm O2 bungs you would have to weld in 18mm O2 bungs. Some aftermarket exhaust systems have both the 12mm and 18mm O2 bungs so check and see what you have. I all reality the narrow band 12mm O2 sensors will work just fine for the mods you have.
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 03:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 01:29 AM
New tuner from Dynojet - "Power Vision" 4getNo1 ECM/Fuel Management systems 103 10-30-2012 06:25 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 08:21 AM
Dynojet Power Vision - and adjustable pushrods CHAINSAW Fuel Moto 0 03-14-2011 05:19 PM
