Screamin' Eagle Chisel Air Cleaner Issue - Road Glide Forums
post #1 of 11 (permalink) Old 02-23-2017, 10:42 AM Thread Starter
Anyone else using this Air Cleaner? I have this on my bike and like the looks of it but there is an issue that it drips/leaks oil out of the bottom side of it. It is a very small amount but I noticed it after riding there will be small streaks of oil on my right side saddlebag where the small drip has flowed back there. I like the Air Cleaner but this is extremely annoying to me. Took it to the dealer and they said this was normal and that I need to clean up the Air Cleaner element about every 1000 miles. Just wondering if anyone else has run across this. Considering changing to a different Air Cleaner because of this.
Gregfry is offline
post #2 of 11 (permalink) Old 02-23-2017, 10:55 AM
transdude's Avatar
You are getting some blow by this happens a lot. I have a Ness Big Sucker and no such issue. Sometimes over filling engine oil can cause this apparently too much pressure and pushes some oil out through the air cleaner.
2016 FLTRX Denim Black; V&H black Propipe; FP3, Ness Big Sucker Intake!
transdude is offline
post #3 of 11 (permalink) Old 02-23-2017, 11:15 AM
WTFranz's Avatar
I have this same issue with the same air intake. Was told to keep my oil level about 1/2 quart low and it seems to work. I also noticed that if I use a lighter oil like WD-40 on the filter I don't get as much or very little and can still keep my oil level full.
There's prob a more technical explanation but I'm not that smart...
WTFranz is offline
post #4 of 11 (permalink) Old 02-23-2017, 11:35 AM
as the others have stated, it is NOT the air filter. Another solution is to install a breather catch system like this
Harley Twin Cam crankcase head breathers system DK Custom
tOSUSteve is offline
post #5 of 11 (permalink) Old 02-23-2017, 11:51 AM
Thermodyne's Avatar
Best way to stop the oil carry over from wetting the breather, is to keep it from ever leaving the motor.
You can enlarge the drain holes in the rocker supports. The little hole to either side of the sharpie #2. 7/64th works well.
Thermodyne is offline
post #6 of 11 (permalink) Old 02-23-2017, 12:10 PM
ChromeSpark's Avatar
I've had one on another bike. First suggestion is to wipe the oil splatter to see if it is red in color or oil color. Mine wound up being red, the filter had been over oiled from the factory. I used paper towels to blot up the excess oil from the filter. I had to do this twice before it stopped. If oil color +1 on reducing oil level by 1/2 quart. The service tech stated that it would stop when the oil level dropped from the blow by, it did, at not quite 1/2 qt low.
"It's a motorcycle, its not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #7 of 11 (permalink) Old 02-23-2017, 12:41 PM
Dragon Dude's Avatar
I'll be checking this out because i will be installing my .030 head gaskets soon and could do it then. Anybody know of any problems because of doing this?
Dragon Dude is offline
post #8 of 11 (permalink) Old 02-23-2017, 01:26 PM
Thermodyne's Avatar
Put a set of rocker lockers in and shim the rocker arms while you're there. For just a few bucks and some time you can get rid of a lot of that 2500 rpm rocker box clatter too.
post #9 of 11 (permalink) Old 02-23-2017, 01:50 PM
Thanks, i already installed some Rockouts and they did do a good job. I did not think i was going any further with aftermarket motor stuff at that time or i would have done everthing when i had it apart. I have lifters making noise so that has steered me in doing everything i want this time.
post #10 of 11 (permalink) Old 02-23-2017, 02:21 PM Thread Starter
Thanks to all for the quick replies. Not sure what/how I will handle this but I need to look into the breather catch system from DK.
Gregfry is offline
Screamin Eagle Chisel Extreme Second Wind Parts for Sale 11 06-15-2018 09:11 PM
Screamin eagle air Agitator air cleaner Orange09Glide Parts for Sale 1 10-18-2014 12:49 PM
17 inch Chisel on a 2000 Screamin Eagle RG Harleywood Wheels and Tires 1 01-10-2014 05:56 AM
