Power Vision Gauges - Road Glide Forums
post #1 of 5 (permalink) Old 03-14-2013, 08:33 AM Thread Starter
Power Vision Gauges
Have a question for you guys with your PV mounted. What gauges do you monitor while riding, like rpm, temp, mpg, what is knock? What do you have them set at? I just mounted mine and would like to set it up. What is the ideal running temp? Whats to low whats to hot? I'm not sure what knock is and would it be something to monitor whats good whats bad? Thanks ride safe.
2013 FLTRX Candy Orange/16" Madstad/Fuel Moto Jackpot SS 2/1/Power Vision/Daymaker/CD LED's Plasma Rods/Boom saddlebag speakers/amp/Heritage Strech Bars/Zumo 660
ZAKMANDO is offline
post #2 of 5 (permalink) Old 03-14-2013, 09:30 AM
I generally monitor the AFR, MAP,and head temp, if I leave mine mounted when not logging tune data. Did not notice that there was a "Knock" gauge, but will assume it counts knock events detected by the factory system. Knock is when the cylinder fires when not intended, and is a bad thing.
Jeff
akjeff is offline
post #3 of 5 (permalink) Old 03-14-2013, 10:12 AM
PGR
PGR's Avatar
I monitor MPG and engine temp
Ron..........................
PGR is offline
post #4 of 5 (permalink) Old 03-14-2013, 07:00 PM
No expert by any means I set my min temp in blue to 180 and usually will not drive away untill it has idled down and take it easy until at least to minimum now max \i set red and have it at 325 . I set the colors so I don't spend so much time looking at the numbers just that I am not minimum or maximum . I usually have it monitoring what gear mileage and anything else I feel like .
cbumdumb is offline
post #5 of 5 (permalink) Old 03-15-2013, 08:08 AM Thread Starter
Thanks cbumdumb, I wanted to watch the temp just didn't know the low/high numbers. This will be my second riding season with this PV it will be nice having it on the bars this year to monitor engine data, instead of the factory air temp gauge that lets you know the temp under your faring.
ZAKMANDO is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
power vision/gauges rebeltitanfan63 ECM/Fuel Management systems 4 08-05-2015 01:17 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
New tuner from Dynojet - "Power Vision" 4getNo1 ECM/Fuel Management systems 103 10-30-2012 05:25 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
