Fuel pump questions for tech's - Road Glide Forums
post #1 of 6 (permalink) Old 03-26-2013, 06:56 PM Thread Starter
faststan's Avatar
I changed the fuel pump from my silver tank to my red tank. I noted that there are 2 ground wires, one on the fuel filter to pressure regulator and one from the wiring plug to the top plate. These both appear to plug/screw into plastic. Are they both for static electricity? It seemed odd. Any help you can give will be appreciated.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #2 of 6 (permalink) Old 03-29-2013, 06:56 PM
jim540's Avatar
They could be. You definitely need to be grounded when fueling. Seems odd that they would go to plastic. Is the plastic just a connection point with another ground?
2011 RGC, 103 engine, custom seat, Drogo's Dragula exhaust, Drago's 565 cams, ported and polished heads, HD Heavy Breather intake, Thunder Max tuner, Heritage style bars, Hawg Wired Six Pack audio system, Mean City Cycles modified seat ΜOΛΩΝ ΛΑΒΕ
jim540 is offline
post #3 of 6 (permalink) Old 03-29-2013, 07:35 PM Thread Starter
faststan's Avatar
Not that I can tell. The top plate appears to be a molded plastic solid piece. The wire attached for the pressure regulator just screws into the same fitting the fuel filter is attached with. The other wire plugs into a recess in the top plate, coming from the fuel pump wiring harness. I can't see any place where there is metal that is attached to.
One of the wires is #24. The other is in the harness.
faststan is offline
post #4 of 6 (permalink) Old 03-29-2013, 07:42 PM
jim540's Avatar
Check this video.
http://www.youtube.com/watch?v=SYOsc7NBhBo
jim540 is offline
post #5 of 6 (permalink) Old 03-29-2013, 08:05 PM Thread Starter
faststan's Avatar
Thanks Jim. I think I have viewed every youtube and other video's. The 09-13 use a different fuel pump than the previous models and I have yet to find a video for the newer bikes. They changed when they went to the 6 gallon tank. I even signed up for FixMyHog hoping they had a video but they don't have plans until later this year.
faststan is offline
post #6 of 6 (permalink) Old 03-29-2013, 08:07 PM
jim540's Avatar
Well we tried. Good luck with your project.
jim540 is offline
Garmin Road Tech 660 GPS w/Kuryakyn Fuel Door Mount (Black) Bunker Parts for Sale 5 06-03-2017 02:22 PM
Tech Tuesday Fuel Moto blog fuelmoto Fuel Moto 1 02-02-2016 11:02 AM
Fuel Moto 107" hi output R&D motor 151Hp Pump Fuel fuelmoto Dyno Results 5 01-22-2014 07:24 PM
Road Tech Zumo 665 wiring questions Govdog76 GPS 10 05-20-2013 08:48 PM
cb radio tech questions mea4dxl Tech Area 2 09-08-2012 09:43 PM
