Power Vision On Bars - Road Glide Forums
post #1 of 8 (permalink) Old 03-28-2013, 03:44 PM Thread Starter
mhud3780's Avatar
I'd like to know how many of you actually mount the PV on your bars. If you leave it there what do you use it for after you have perfected your tune? Did you use the mounting hardware from FM?
I'm hesitant order mounting hardware as I have my Zumo of the left side and don't really see how I would use the PV daily. It seems like it might be just something else to have to remove when leaving the bike unattended. Am I missing something?
Thanks fellow!
2013 RGU after trading 2008 RGU with 72k. I love these bikes. "Life is highway made to be enjoyed on two wheels."
mhud3780 is offline
post #2 of 8 (permalink) Old 03-28-2013, 03:49 PM
direwolf's Avatar
I have it mounted to mine, but not with there hardware, I have the mount for my HDtech GPS and have it velcroed to the removable piece that come out in order to snap the GPS in. If you want I'll take some pix tomorrow & post.
...2009 SERG...Last of the Hand Built's..
direwolf is offline
post #3 of 8 (permalink) Old 03-29-2013, 08:24 PM
I use my old Magellan GPS mount , you can't use visor. I mount mine locally but will remove for long trips because some douchebubble will think it is a GPS or a small television and steal it. If I need it I will just hook it up.after tune is done its unneeded unless you need to check something .
fat boy ultra is offline
post #4 of 8 (permalink) Old 03-30-2013, 07:47 AM
elbohead's Avatar
I ordered this mount (see pics) on the advice of a forum member (can't remember who) and was hesitant at first because of the plastic construction. It's actually pretty rugged and I don't sweat mounting my $500 PV there anymore. PV also goes on and off easily (seconds) by spinning the nut around the ball. Of course that is if you leave the mount on the bar. I think I paid around $17.
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
post #5 of 8 (permalink) Old 03-30-2013, 08:27 AM
tdkkart's Avatar
I used the techmount that FM sells:
Securely mounts the PV most anywhere, I've got mine permanently mounted just to the lower left of the speedo/tach. Still easy to get on and off as needed.
If you don't know how you'd use the PV on a daily basis, unfortunately you're missing out on at least 50% of the unit's functionality. I have 20 gauges set up for viewing as I want, datalogging, trip/mileage computer and code reader at the touch of the screen.
I'm a tech/motorhead geek so I do this stuff.
tdkkart is online now
post #6 of 8 (permalink) Old 03-30-2013, 09:07 AM
NORSEMAN's Avatar
Ditto. I used the FM mount that came with the kit. I have the Zumo up high next to my clutch hand, and the PV down low (permanently mounted) as per tdkkart.
2016 SGS CVO
NORSEMAN is offline
post #7 of 8 (permalink) Old 04-20-2013, 04:48 PM
StriderJim's Avatar
routing PV cable for handlebar mount?
How do you do it?
thanks,
StriderJim.....................Blog:
StriderJim is offline
post #8 of 8 (permalink) Old 04-20-2013, 05:20 PM
elbohead's Avatar
I ran mine under the tank dash. Plenty of room.
elbohead is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
New tuner from Dynojet - "Power Vision" 4getNo1 ECM/Fuel Management systems 103 10-30-2012 05:25 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
Dynojet Power Vision - and adjustable pushrods CHAINSAW Fuel Moto 0 03-14-2011 04:19 PM
