Screamin Eagle tuner - Road Glide Forums
post #1 of 9 (permalink) Old 03-29-2013, 01:08 PM Thread Starter
I had the Screaming Eagle tuner took it back to Harley for them to reset it back to factory and bought the power Commander 5 how do you tell if Harley removed the screamin eagle tuner?
drmudd is offline
post #2 of 9 (permalink) Old 03-29-2013, 01:17 PM
faststan's Avatar
The SEPST/SERT is a download tuner. It is not attached to the ECM unless tuning. The PC-V is an 'attached' tuner. It constantly overrides the ECM as you drive based on a set map. If the PC-V is attached the SERT is not present and effecting your tune.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 9 (permalink) Old 03-29-2013, 01:40 PM Thread Starter
power commander told me that the program needs to be put back at stock programming in order for it to work with their tunerI tried some of the maps that's power commander hasbut they are not working correctly,I have a 2012 103 with255 cams big air kit and Reinhart true dual s
drmudd is offline
post #4 of 9 (permalink) Old 03-29-2013, 02:08 PM Thread Starter
thanks for the info
drmudd is offline
post #5 of 9 (permalink) Old 03-29-2013, 04:08 PM
faststan's Avatar
Whoever sold you the PC-V should support it. If you bought it from your dealer take it back there. In any case, you may have to have it dyno tuned to get it right.
faststan is offline
post #6 of 9 (permalink) Old 03-30-2013, 09:11 AM
crossbonesglide's Avatar
02 sensors
Did they disconnect the 02 sensors? I believe the Power Commander needs these disconnected, otherwise the ECM will recalibrate to the lean settings.
crossbonesglide is offline
post #7 of 9 (permalink) Old 03-30-2013, 09:14 AM Thread Starter
yes 02 sensors are disconnected found a map that works pretty good but it doesn't have the 255 cams on that map
drmudd is offline
post #8 of 9 (permalink) Old 03-30-2013, 09:21 AM
Fuel map
If you bought it from Fuel Moto they could build a fuel map for you. Otherwise you'll have to wait for Dynojet to make one. Why did you dump your original tuner?
post #9 of 9 (permalink) Old 03-30-2013, 03:17 PM
jerseyjeff62's Avatar
been trying to get on power commander website and it comes up Service unavailable ?
need to download main software and maps
2017 Road Glide Special
Laguna Orange
jerseyjeff62 is offline
Screamin eagle super tuner 32109-08c - UNOPENED Cskwared Parts for Sale 1 10-06-2015 03:56 PM
Screamin eagle race tuner tech643 Parts for Sale 4 10-06-2015 12:31 PM
Screamin eagle pro tuner map for 120 r into 2015 roadglide c3sar3 ECM/Fuel Management systems 1 03-29-2015 01:49 AM
Screamin Eagle Pro Tuner reflash question RootBeerFXS ECM/Fuel Management systems 6 03-20-2015 07:00 PM
Screamin’ Eagle® Pro Super Tuner Steve ECM/Fuel Management systems 5 08-03-2011 08:01 PM
