Can you reset the stock ecm? - Road Glide Forums
post #1 of 18 (permalink) Old 03-30-2013, 07:50 PM Thread Starter
garvin90's Avatar
Sooooo I'm curious to know if just like on a cage, if you touch the positive and negative cables together will it clear the ecm? Didn't know if this would work or not. Since I added slip ons over the winter wasn't sure if I should just leave it be or not till I get a tuner.
2012 Chrome Yella!
garvin90 is offline
post #2 of 18 (permalink) Old 03-30-2013, 07:56 PM
elbohead's Avatar
If all you did was add slip ons you shouldn't have to worry about a tune. I don't think I'd touch the cables together.
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
post #3 of 18 (permalink) Old 03-30-2013, 08:16 PM Thread Starter
garvin90's Avatar
That's in addition to the a/c from s&s I've had since swii.
2012 Chrome Yella!
garvin90 is offline
post #4 of 18 (permalink) Old 03-30-2013, 08:24 PM
Peewee's Avatar
You still running stock head pipe w/cat? And has the check engine light came on?
"Know Thyself"
Peewee is offline
post #5 of 18 (permalink) Old 03-30-2013, 08:26 PM Thread Starter
garvin90's Avatar
Don't remind me... but yes
2012 Chrome Yella!
garvin90 is offline
post #6 of 18 (permalink) Old 03-30-2013, 08:37 PM
Peewee's Avatar
Get you a degutted head pipe and get a download from the dealer, you'll be fine. But if you plan on more motor work get a tuner. Problem isn't in the slip ons, but with the a/c
"Know Thyself"
Peewee is offline
post #7 of 18 (permalink) Old 03-30-2013, 08:48 PM
93-331-29psi's Avatar
Dealer download isn't going to work with a gutted head pipe. The download assumes you're using the cat you need an aftermarket tuner of some sort or the stock A/C needs to go back in. Don't run it this way as its way too lean. Time will equal damage.
Sent from Motorcycle.com App
93-331-29psi is offline
post #8 of 18 (permalink) Old 03-30-2013, 10:11 PM
triumphwes's Avatar
He's correct, the MoCo downloads are built on the assumption that all EPA components (cat converter) are in place. Once they're removed, you will be running lean.
These air cooled motors do not respond well to running lean.... If you're catching an MIL, then your ECM has confirmed that you are running outside of it's available fueling tables.
2013 FLTRU
Stuff
No job is so easy that it can not be done wrong
triumphwes is offline
post #9 of 18 (permalink) Old 03-30-2013, 10:43 PM Thread Starter
garvin90's Avatar
What's a MIL?
All I've done so far is my s&s open element a/c and a set of se thunder street 3 ˝s. I really don't even care about changing my head pipe out right now either. That's why I'm trying to avoid buying a $800+ tuner. Any suggestions?
2012 Chrome Yella!
garvin90 is offline
post #10 of 18 (permalink) Old 03-30-2013, 10:59 PM
triumphwes's Avatar
Originally Posted by garvin90 View Post
What's a MIL?
Malfunction Indicator Light (Check engine Light). When you installed the high flow air cleaner kit, you allowed more air into the combustion chamber (good), but the ECM's stock reference tables have very little options to correct for the increased air charge. Which is why you have the MIL. Even with the stock header with the cat intact, you'll still inhale more with the upgraded intake. If you were at my counter, I'd recommend either a basic fueler, or at minimum the stage 1 ECM flash.
2013 FLTRU
Stuff
I Can't Wait I Can't Wait I Can't Wait......The Outdoors SteadyEddie General Off-Topic Discussions 15 05-19-2017 02:57 PM
Do I need a tuner, or can I have the Delphi ECM reflashed? EdMac *General Road Glide Discussions/Pictures 4 08-01-2015 10:19 AM
Ecm password reset garbage cannon ECM/Fuel Management systems 6 05-27-2014 06:42 AM
Power vision, reset fuel trims? Rkfltrx ECM/Fuel Management systems 5 05-25-2012 03:28 PM
Odometer reset Bluestone Tech Area 4 01-12-2012 11:04 AM
