Initial Sputtering on Start Up After Auto Tuning w PV - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 06-14-2017, 01:04 PM Thread Starter
JDisMe's Avatar
So I've been running a map that I got from Fuel Moto and I finally got around to auto tuning and before I even started riding, when I started the bike (I put the PV in auto tune before starting the bike), here was some kind of flashing over the auto tune cells saying "warm up" or something. I noticed right away that if I gave it some throttle, it would sputter and want to die. After like a minute, it was fine...
Rode 10-15 minutes and installed the auto tune corrections, then rode another 10-20 minutes and installed that one.
My bike feels like it is running a lot smoother and has better response. It felt like it was still running pretty hot but it definitely was running better.
So the next day, I unplug my PV and it still does this sputtering for like the first minute after initial start up. It never did that before my auto tuning began.
I'm wondering if I should re load the original tune and not start the tuning process until the bike is running already.
It never sputtered before and my buddy said he saw smoke coming out of the pipes at start up. So I'm thinking it's running rich at start up for some reason instead of lean.
Anyone had this issue with the auto tune basic?
Appreciate any insight here. I have a long trip coming up and don't want to screw anything up.
P.S. Forgot to add my set up: Drago's H Pipe w Dragula's, FM AC and PV.
--2019 RGS--
--2012 Road Glide Custom--Gone But Not Forotten
JDisMe is offline
post #2 of 14 (permalink) Old 06-14-2017, 07:49 PM
I have not used auto tune basic. Like you I am running a fuel moto map and the bike runs great. Still runs hot though. I was told the only way to cool them down is change the cams. Something about the stock cams valves opening and closing makes it run hot. My thought is if you run auto with stock O2 sensors your running the afr at 14.7 on auto tune. That's not gonna make it run cooler. Maybe I am wrong. Hopefully someone smarter than me will reply.
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #3 of 14 (permalink) Old 06-15-2017, 09:33 AM
Are you sure it is not still in auto tune?
conn-e-rot is offline
post #4 of 14 (permalink) Old 06-15-2017, 09:39 AM
That is what it sounds like to me too. I don't have a PV, but I do use an FP3 and when it is in auto-tune mode it runs like like midget on marbles. Unless you close the auto-tune session and apply the tune, it will perpetually stay in that mode forever. Once again, I am just relating my experience with my tuner, so the PV might work differently.
macabra11 is offline
post #5 of 14 (permalink) Old 06-15-2017, 10:01 AM
with PV you have to export learned from auto tune screen
disable auto tune
load tune
If you didn't disable it you are still running in auto tune
watch this video
https://www.youtube.com/watch?v=y-x9NcQ5TWc
post #6 of 14 (permalink) Old 06-15-2017, 10:10 AM Thread Starter
JDisMe's Avatar
It's not still in auto tune. I had it off the bike and completely disconnected and it still did the sputtering for the first minute of start up.
I was thinking the same thing at first. I figured once I took the PV out, it would go back to normal, but nope.
Sent from my SM-N920V using Tapatalk
--2019 RGS--
JDisMe is offline
post #7 of 14 (permalink) Old 06-15-2017, 10:21 AM
Unplugging it does not turn the settings back on that the auto tune disables this is a flash tuner not a piggy back
JDisMe and macabra11 like this.
post #8 of 14 (permalink) Old 06-15-2017, 11:31 AM
^^^^This.
post #9 of 14 (permalink) Old 06-15-2017, 12:35 PM
Contact Jamie at Fuel moto send him your tune and he can look at what is going on with it and he will adjust and send the tune back to you.He will work with you till it's right i know i been through this.
JDisMe likes this.
steve2100 is offline
post #10 of 14 (permalink) Old 06-16-2017, 03:09 PM Thread Starter
JDisMe's Avatar
Great info guys.
I originally watched the older Dynojet auto tuning video on YouTube and I watched it again and he never mentions disabling auto tune, so maybe that's what I did. Ugh.
I'll check when I get home after work and see if I was a dope!
JDisMe is offline
Screamin' Eagle Smart Tune Pro Auto Tuning Module newfie ECM/Fuel Management systems 16 03-31-2019 09:30 PM
Engine noisy at initial startup after cam install warbird458 Engine Related 6 07-12-2016 11:50 AM
PV Auto tune not naming files sequentially Cash_ ECM/Fuel Management systems 1 06-07-2013 07:04 PM
PV auto tune Deadstroke ECM/Fuel Management systems 0 04-23-2013 10:06 AM
2010 FLTRX sputtering after exhaust removal kmokarry Troubleshooting for Road Glides 7 06-09-2012 03:17 PM
