Power Vision and Open Loop Tables - Road Glide Forums
post #1 of 3 (permalink) Old 04-04-2013, 09:00 AM Thread Starter
triumphwes's Avatar
A question for the folks out there proficient with Power Vision tuners. In Auto Tune Basic, does it attempt to make any correction for open loop operation (heavy load, WOT, etc..)?
I know the Pro version does with the WB sensors, just wondering if the Basic mode makes any "blind" assumptions for the AF tables...
Thanks so much for any insight you guys may provide!
2013 FLTRU
Stuff
No job is so easy that it can not be done wrong
triumphwes is offline
post #2 of 3 (permalink) Old 04-04-2013, 02:49 PM
faststan's Avatar
Start with a map for your installed equipment. The autotune basic will populate changes into a new map thru-out the operating range.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 3 (permalink) Old 04-04-2013, 02:52 PM
bikerglasses's Avatar
Is it worth getting auto tune instead of a dyno run and custom map?
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
Tags
adaptive fuel tables , autotune basic , power vision
New Target Tune for Dynojet Power Vision offers wideband closed loop tuning fuelmoto Fuel Moto 24 09-22-2015 10:02 AM
TTS experts - merging fuel tables and VE tables from 2 tunes modot66 ECM/Fuel Management systems 6 09-12-2015 03:32 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Power Vision Spark Tables vaughtcity ECM/Fuel Management systems 0 04-08-2013 09:26 AM
Air lift tables swampercj General Off-Topic Discussions 7 02-10-2011 12:54 PM
