Need a tuner? - Road Glide Forums
post #1 of 4 (permalink) Old 04-06-2013, 07:18 PM Thread Starter
powergod's Avatar
Need a tuner?
Have decatted the header, cvo slip ons and screaming eagle chiseled intake need a tuner or just well enough alone?
If you can read this thank a Teacher
If its written in English thank a Soldier
2011 Road Glide Ultra
powergod is offline
post #2 of 4 (permalink) Old 04-06-2013, 07:41 PM
Definitely get a tuner.
post #3 of 4 (permalink) Old 04-06-2013, 07:56 PM
tj316's Avatar
get a tuner , your in IL call Frank Drago he will help you out
tj316 is offline
post #4 of 4 (permalink) Old 04-06-2013, 08:14 PM
Torquey's Avatar
Most will say definite tuner. Try it out. If the ECM can handle the mods, the removed CAT will also allow the engine to run cooler. If you need something, forget a download and get a tuner.
If my FatBoy, I had stage 2 intake, and a 2:1 with no cat, everything else stock. Bike ran like a champ without a tuner. I know that a $400 tuner and a few dyno runs would have coaxed another 3 HP and 4 pounds more torque out of the stock engine...
Torquey is offline
Need help - need a tuner with some skills in SW Mich Captain America Dyno Results 1 06-02-2017 11:51 PM
SERT Tuner Obsolete, Not functioning, Buy new Tuner? hawk06Glide Dyno Results 22 04-04-2016 12:22 PM
SE tuner and Power Vision tuner question bigshaqa *General Road Glide Discussions/Pictures 8 01-11-2015 09:35 PM
tuner no tuner WTH????? motosig102 Intake and Exhaust 19 06-16-2013 02:36 PM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 10:00 AM
