Harley 103 ecm - Road Glide Forums
post #1 of 1 (permalink) Old 08-16-2017, 11:01 PM Thread Starter
Harley 103 ecm
Question.... When a person installs a powercomander 5 on their 2015 103 you disconect the o2 sensors then install the by pass plugs that tells the computer the o2 sensors are still there. However the ecm is looking to keep the bike at predetermined fuel ratios i am guessing 14.7.1 So does the ecm just stay with one map now thinking that the fuel ratios and timing are never changing based on engine load etc. And also is the ecm on these bikes gear calabrated like the pc5 or just maps the computer has. Basically i am wondering what inputs the ecm is using to build its fuel maps for the bike. Amd what pc5 is interrupting and able to change.
t-tracks is offline
Harley ECM Reflash vs. Aftermarket RoadglideinMO ECM/Fuel Management systems 32 05-16-2018 10:46 PM
2011 RG 103 Engine not only half a 103 Forger Road Glide Specific Discussions 21 12-13-2010 09:12 PM
I prolly need an ECM upgrade SKULLZ ECM/Fuel Management systems 8 11-24-2010 10:22 AM
Factory 103 vs Dealer-installed 103? HD_Shock Road Glide Specific Discussions 18 10-11-2010 03:06 PM
Newbe has an Exhaust/ ECM Feul Mgmt Question whataglide ECM/Fuel Management systems 3 08-17-2010 02:31 PM
