MicroTuner vs PC5 vs PV? Help needed from you FM gurus. - Road Glide Forums
  • 1 Post By Lima14
post #1 of 4 (permalink) Old 08-20-2017, 10:09 AM Thread Starter
beatlesfab4fan's Avatar
OK question for you fuel management guys.
My Shark: 15, 103, Screaming eagle Ventalator Elite A/C, Decatted headpipe, closed end cap Supertrapps.
My problem: Too much heat, decel pop.
I already know I need to fatten up the A/F ratio. I have no intention of doing any other mods(cams etc) so cost/performance standpoint, am I better off going with say, a FuelMoto Micro Tuner, ordo I still need to go with a PC5 or PV or one of the other expensive tuners?
As a side question, what are the differences between the $200 one vs the $500 one?
Any and all help is greatly appreciated.
TIA,
Mike
beatlesfab4fan is offline
post #2 of 4 (permalink) Old 08-20-2017, 11:16 AM
TIA,
Mike
Whatever you do don't get a FP3. You won't be able to do anything and pretty much waste your money once you do cams. Even a stage one I feel like you're leaving numbers off the table
beatlesfab4fan likes this.
Lima14 is offline
post #3 of 4 (permalink) Old 08-20-2017, 10:51 PM
Desertwndrr's Avatar
Power Vision if you are limited to options from FuelMoto. I use TTS personally, but you'd have to source one elsewhere. Whatever you do, use a flash tuner. Don't waste your time with a harness box.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #4 of 4 (permalink) Old 08-22-2017, 05:41 AM Thread Starter
OK so I am fuel management ignorant. Whats the difference between a flash tuner and a harness box?
Also why not the FP3?
TIA
Mike
Gutted Cat, A/Filter, & FM PV... V-man Intake and Exhaust 16 02-03-2019 04:29 AM
New 16 FM Jackpot-PV Install chriscalabro Fuel Moto 3 10-08-2016 11:43 PM
2015 RG and microtuner BBecker ECM/Fuel Management systems 3 09-22-2015 09:26 AM
PC5 with auto tune. HELP!!! OneSlickGlide ECM/Fuel Management systems 9 06-23-2014 11:24 PM
Couple of questions for all you GURUS boneman171 *General Road Glide Discussions/Pictures 3 04-28-2012 10:17 PM
