T Max Question - Road Glide Forums
post #1 of 29 (permalink) Old 04-19-2013, 12:22 PM Thread Starter
SMOKENJOE's Avatar
T Max Question
Everytime I look at a T Max video I see the afr on screen being adjusted with the green squares how can I see the adjustments while my bike is running with the Tmax tune on and I dont mean the gauges
SMOKENJOE is offline
post #2 of 29 (permalink) Old 04-19-2013, 12:43 PM
tsmartt's Avatar
Try opening the pages for AFR on the tree under Tuning Maps. Just make sure you are linked and monitoring. Hope this helps.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #3 of 29 (permalink) Old 04-19-2013, 01:03 PM Thread Starter
SMOKENJOE's Avatar
Next that didn't work but thanks
post #4 of 29 (permalink) Old 04-19-2013, 01:29 PM
TRUBlue's Avatar
I'd recommend sending them a message via the data collection menu while linked. I've been going back and forth with them all week on a few issues that have helped resolve several issues. They will then send you an email in response.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #5 of 29 (permalink) Old 04-19-2013, 06:49 PM
Black 3's Avatar
Is the screen you are talking about, the 1 while the bike is being dynoed?
Black 3 is offline
post #6 of 29 (permalink) Old 04-19-2013, 07:27 PM
Q-Hog's Avatar
The operations of the TMax is not as simple as it is advertised or bragged upon... I'm having issue with my tuning.. JMO.
Q-Hog is offline
post #7 of 29 (permalink) Old 04-19-2013, 07:33 PM Thread Starter
SMOKENJOE's Avatar
Reply From ThunderMax
Here is what I got in email this didn't work the rpm line is there but no adjustments being made even tried a different map no luck
Joe,
When you are linked to the bike, Click the MONITOR button next to the LINK button.
They must both be green.
To the far left of the LINK and MONITOR buttons, you will see TUNING MAPS.
Below this, Click on the "+" symbol next to Front Cylinder Fuel. This will expand a list of different fueling maps.
Scroll down and click on line that says "Front Fuelflow vs TPS @ 1024".
As you apply throttle, you should see a verticle line on the screen move to the right in coordination with your throttle movement. This indicates the Throttle Position.
As this line passes areas that need adjustments made, you should see the green points being created above or below the original points.
Be sure to adjust the map you are looking at to match the RPM level you are trying to tune.
Sincerely,
Brian Harbin
Thunder-Max Customer Support
post #8 of 29 (permalink) Old 04-19-2013, 07:36 PM
Q-Hog's Avatar
Like I said... Not user friendly..
Q-Hog is offline
post #9 of 29 (permalink) Old 04-19-2013, 08:05 PM Thread Starter
SMOKENJOE's Avatar
Thats to bad I agree the support so far sucks Jamie at fuelmoto sent me a map the map was for an 09 exhaust system I have a Fuelmoto 2 into 1 go figure they tell me almost any map will work just let it learn well school is out for my TMax the have an advanced software that lets you make maps but so far its a pipe dream I have posted trying to get it with no help from TMax
post #10 of 29 (permalink) Old 04-19-2013, 08:29 PM
Q-Hog's Avatar
I've rode 1900+ miles & my Tmax hasn't learned S#*+ yet.. I'm bout to get ride of it & my pipe & just start over. My RG road much better stock...
Q-Hog is offline
Question for Schuberth C3, C3 Pro, or RPHA Max Guys DMcBiker Helmets 9 06-12-2015 10:35 PM
RPM @max fuel economy for a stock 96ci BigBadandPlaid ECM/Fuel Management systems 9 09-16-2011 02:59 AM
Thunder Max? mrmoto95 ECM/Fuel Management systems 10 09-13-2011 12:54 PM
Stock ECU & VH Fuelpak vs T-Max Autotune DAK47 ECM/Fuel Management systems 3 12-03-2010 09:48 PM
