FP3 Question - Road Glide Forums
 4Likes
post #1 of 13 (permalink) Old 09-21-2017, 03:44 PM Thread Starter
FP3 Question
I have a 2015 RGS, with stock exhaust and will not be gutting the cat(I do not want a louder exhaust). I do have a stage 1 download and breather set up. I am looking to install a FP3 for the auto tune ease of install. After the FP3 install I am hoping to cool the exhaust a bit without hurting the gas mileage too much, and better performance.
I see on V&H web page there are two FP3s that can be used on my bike. One being the Cali version which I am sure it is limited in function and one for off road use (like many types of engine mods). For those that have the FP3, which version have you used and what suggestions might you have. Also, where would be the best place to purchase one.
Thanks
FLTRXS18 is offline
post #2 of 13 (permalink) Old 09-21-2017, 04:11 PM
Spazz's Avatar
Thanks
If you are NOT in Calif.... get the 49 state model...
Sent from my SM-G955U using Tapatalk
RENO BAGGER AUDIO
Spazz is online now
post #3 of 13 (permalink) Old 09-21-2017, 04:38 PM
RFG7680's Avatar
I have the 49 state one. Which is the only one I'd get. I put it on my stock 16 a while before I did the cat and mufflers. Big difference. Also change the throttle response to standard plus.
RFG7680 is offline
post #4 of 13 (permalink) Old 09-21-2017, 04:43 PM
Dice21's Avatar
With stock exhaust, the FP3 is going to do little to nothing for you. I'm pretty sure stock exhaust is not even a choice for a tune. You may get a little gain, but it won't do anything for the heat. You're not going to lower the exhaust temp a significant amount, and the cat is still going to be just as hot. If it's running good now, you might want to save the money.
SteadyEddie likes this.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #5 of 13 (permalink) Old 09-21-2017, 04:59 PM
RFG7680's Avatar
There is a tune for a stock bike. And it does make a difference. It's not as much as when the cat is out. But it does help. And changing the throttle response to standard plus makes it a whole new bike. Mine was in my stock 16 for about a month. I'd do it all over again even if I wasn't changing the pipes.
VikingRider likes this.
RFG7680 is offline
post #6 of 13 (permalink) Old 09-21-2017, 06:13 PM
sfcusaret2004's Avatar
another great thing about the FP3 is that you can pick one up at the local HD dealer. Even though it literally is a plug and play device, if your dealer installs it,(if they quote you over .25 hours for the install, RUN) it will not compromise your warranty either. As far as performance improvement, it literally will fine tune your performance and as others have said just the throttle response upgrade almost makes it worth it. I'm running Rush "Big Louies" 4" slip ons and a Kuryakyn Mach 2 intake with no internal mods and once I did a full weekend auto tune my gas mileage went up from 35-38 to 38-40 MPG, plus the bike "feels" better, and the response is night and day.
RFG7680 likes this.
sfcusaret2004 is offline
post #7 of 13 (permalink) Old 09-21-2017, 06:20 PM
HOGPRO has the tuner at a discounted price....
VANCE AND HINES FP3 FUELPAK 66005 - EXHAUST/FUEL
squirrelsnest is offline
post #8 of 13 (permalink) Old 09-21-2017, 07:21 PM
CHOP!'s Avatar
I put the 49 state on my '17 RGU. Absolutely love it.... I have tailgunner slip-ons now and looking to put dresser duel headpipes and get rid of the cat soon. After that will be the intake. I went ahead and took the plunge with the FP3 now so that I am able to make tune changes as I do other upgrades. I don't see a big heat difference but response and get up and go, big improvement. I would definitely recommend it.
CHOP! is offline
post #9 of 13 (permalink) Old 09-21-2017, 07:28 PM
I have a FP3 on my wife's 16, definitely didn't go with the Cali model. Had stock exhaust until last March. Fuel economy is great unless you get on it, just like anything else. Riding 80-85 we manage to easily go 200+ miles before starting to worry about gas. Of course at 60-70 you can go a bit further............
post #10 of 13 (permalink) Old 09-22-2017, 07:50 AM Thread Starter
All, thanks for the replies I have one on order. Iím definitely going to adjust the throttle response to standard +. The nice thing about this is if I change my mind about gutting the exhaust, all I have to do is a retune.
FLTRXS18 is offline
FP3 question railer60 ECM/Fuel Management systems 3 08-26-2016 07:17 PM
Fp3 map question. RFG7680 ECM/Fuel Management systems 2 07-31-2016 07:52 PM
Anyone using the V&H FP3 garbage cannon ECM/Fuel Management systems 23 09-07-2015 08:46 AM
V&H Fuelpak FP3 available from Fuel Moto fuelmoto Fuel Moto 10 03-31-2015 09:13 AM
Vance and Hines FP3 12fltrx ECM/Fuel Management systems 1 09-01-2014 10:45 PM
