Excessive Fuel Warnings in Front and Rear Exhaust - Road Glide Forums
post #1 of 4 (permalink) Old 09-28-2017, 08:55 PM Thread Starter
wprvresort's Avatar
Hello all, looking for expert advice. I am using the Vance & Hines Engine Tuner and have been doing Auto Tunes and everything was fine until I did the Stage IV upgrade. Now I am getting the Fuel Warnings on both front and rear exhaust ports. Not sure what to do at this point. There are no settings for this engine upgrade so I am assuming Auto Tune is the only thing to do???? I am doing one more flash tomorrow as I am at 67 parts configures and will be doing a very long ride so hoping for a few more. However, if this does not work, suggestions?
wprvresort is offline
post #2 of 4 (permalink) Old 09-28-2017, 09:48 PM
Swomack's Avatar
I would call V&H and let them look at your data live so they can suggest how to make it right.
They can send you a map to work with your stage
Then you flash it into your FP-3
Then run a full tank on Auto Tune
The data can then be saved
Then you flash that.
Should be good to go after that.
Swomack
My Gallery / Click Below Link
Swomack is online now
post #3 of 4 (permalink) Old 09-28-2017, 10:03 PM Thread Starter
wprvresort's Avatar
I will give that a shot. Thx!
post #4 of 4 (permalink) Old 09-29-2017, 12:42 PM
Thermodyne's Avatar
There is a fixed limit on how far the software can move away from the base map. And you have reached the limit.
Any major changes to the engine or exhaust can cause this. A new map with a closer match will correct it.
And with the competition, you can write the auto learned map, and then start auto tuning from there, with a new set of limits. You'll have to read up on the V$H system to see if it will allow that.
Thermodyne is online now
Excessive Heat From Exhaust rogers9671 Intake and Exhaust 10 10-18-2018 08:07 AM
Excessive idle and engine damage 2016CTRoadGlide Engine Related 12 09-19-2016 06:54 AM
10" Windvest. front and rear turn signals. Rear mount and pegs and highway peg mount. 1346wildcat Parts for Sale 10 04-23-2013 07:34 PM
