Engine stumbling from idle... - Road Glide Forums
post #1 of 6 (permalink) Old 11-21-2017, 11:39 AM Thread Starter
trainz71's Avatar
After the bike warms up good to around 200 degrees, just as I open the throttle to start off, Im getting the pop back through intake and it kills the bike. Doesnt do it everytime, but way too much. Need ideas about tweaking settings in FP3 to solve the issue. 15RGS Stock 103, Arlen Ness Big Sucker, V&H Power Duals, V&H High Outputs. I used V&H suggested map on the app, and Ive ran through about 4 cycles of tuning. Bike runs great. Just the problem with startup on throttle, slight decel pop, not really too bad. Also when I stop, strong smell of fuel, not sure if its running too rich or what, but its really strong. No mods have been made to the V&H map yet. Any help, well appreciated!
2015 FLTRXS - Arlen Ness Naked Stage 1 Big Sucker, Vance & Hines Power Duals
Vance & Hines High Outputs, Vance & Hines FP3
trainz71 is offline
post #2 of 6 (permalink) Old 11-21-2017, 03:35 PM
When I did similar mods, I wound up getting a Dyno tune. The map gets close (usually) but I still had a lot of popping and my plugs were getting burned. Dyno got it much closer and I picked up a few HP.
Rather be a smart a$$ than get no a$$
Sobrluke is offline
post #3 of 6 (permalink) Old 11-21-2017, 03:40 PM
Have you ran the Auto-Tune on it ?
post #4 of 6 (permalink) Old 11-21-2017, 07:23 PM
T-Bone 6937's Avatar
There is also an option the the FP3 to lessen any decel pop. Have you adjusted it?
T-Bone 6937 is offline
post #5 of 6 (permalink) Old 11-22-2017, 08:22 PM Thread Starter
trainz71's Avatar
I ended up contacting V&H and they reviewed my autotuning sessions. They sent me another map by download. I installed it, problem solved.
trainz71 is offline
post #6 of 6 (permalink) Old 11-22-2017, 09:23 PM
BlazingSaddle's Avatar
I always appreciate a follow-up to the original problem. Glad it worked out for you, and thanks.
BlazingSaddle is offline
08 Steady Speed Stumbling FLTRick Troubleshooting for Road Glides 6 07-11-2014 09:30 AM
engine stalls and also idle jumps to 2K at times Ahh-Ho RRMC Troubleshooting for Road Glides 12 01-04-2013 01:28 PM
Engine idle higher ??? BAM BAM Intake and Exhaust 6 12-22-2012 04:13 PM
Engine idle RPM? mandlbarrett Troubleshooting for Road Glides 2 07-05-2012 07:12 PM
2005 Stumbling Nino Troubleshooting for Road Glides 33 12-24-2010 12:10 PM
