Whining fuel system - Road Glide Forums
post #1 of 10 (permalink) Old 05-04-2013, 08:42 AM Thread Starter
Whining fuel system
Hello all,
Yesterday I noticed that the fuel system on my bike seems to be making a low level whine-hiss only can I hear it. (I am sure it is always but the pipes are loud at speed). My question, is this normal? Do any of you have the same issue?
Thanks in advance for any help.
trghd1550 is offline
post #2 of 10 (permalink) Old 05-04-2013, 09:01 AM
I hear it until the fuel pump pressures up Then I start it and can't hear a thing.
Jayray is offline
post #3 of 10 (permalink) Old 05-04-2013, 09:06 AM Thread Starter
I hear the same initial pressurizing Jayray, this however is a low level whine that seems to continue while the bike is running. I am not sure if it is the fuel system make adjustments or if it just the pump.
post #4 of 10 (permalink) Old 05-04-2013, 09:30 AM
You will hear it on initial start up and sometimes hear it at an idle. Its the fuel pump running. When you stop hearing it is when you need to worry.
post #5 of 10 (permalink) Old 05-04-2013, 11:35 AM
crossbonesglide's Avatar
Same noise as when you first prime the pump at startup? Might not be the pump but an other engine noise your hearing? Any question stop by the dealer. I hear a whiny noise but it's after 500 miles located near the rear of the bike. Turned out to be the wife.
crossbonesglide is offline
post #6 of 10 (permalink) Old 05-04-2013, 07:07 PM
ogunquitre's Avatar
Send a message via AIM to ogunquitre
Mine just started yesterday with a high pitch quiet whine around the fuel tank area. Cant really isolate it. Here's an interesting link which is the direction I will be going next rainy day.
http://www.hdforums.com/forum/evo-cl...ly-on-efi.html
I can only hear it when the engine is running at idle, exhaust noise over powers it when moving.
Don't waste a day..
ogunquitre is offline
post #7 of 10 (permalink) Old 05-04-2013, 08:09 PM
ogunquitre's Avatar
Also if its more of a hiss, check your Purge tube fitting and make sure it's capped. No cap = hiss..
Located between the heads under the tank.
Don't waste a day..
post #8 of 10 (permalink) Old 05-04-2013, 09:43 PM
Soonerglide's Avatar
A low whine with a hiss thrown in? Hmmm....I think you have my ex wife trapped in your fuel system!!!!!!!!!!!!!!!!!!!!!!!!!!!! DO NOT, I REPEAT, DO NOT LET THAT BITCH OUT!!!!!!!!
2004 Glide "Dirty Juanita"
Fill your hands, you Sonuvabitch!!!
Soonerglide is offline
post #9 of 10 (permalink) Old 05-04-2013, 10:08 PM
Kevsbigred's Avatar
Holy crap man. That is just hilarious!!!!!!
Kevsbigred is offline
post #10 of 10 (permalink) Old 05-04-2013, 10:48 PM
I noticed it after the bike was shut odf and opened my gas cap and it went away
2013 RGU, black of course....
y2kflhr is offline
Full SE vs VH Exhaust System w/ Stage 2 Sound System RoadWolf1172 Intake and Exhaust 23 12-26-2017 01:33 PM
Whining noise at temp rolling_again Engine Related 11 04-13-2017 07:59 AM
Dyno tuner in Alabama - and what fuel management system justaguy ECM/Fuel Management systems 2 06-24-2013 10:23 AM
Video: Fuel Moto Jackpot 2 into 1 Exhaust System w/ High Output Core cyclescoot Intake and Exhaust 9 03-18-2013 06:22 PM
COBRA Fuel Managment System mrbill ECM/Fuel Management systems 4 11-01-2010 05:21 PM
