Tuner/Dyno - Road Glide Forums
post #1 of 8 (permalink) Old 05-05-2013, 12:20 PM Thread Starter
Tuner/Dyno
First off like to say the family genes of being mechanically inclined must of skipped a generation because I am mechanically declined. I am in the process of putting on the dragula 2-1 exhaust and a heavy breather. I was told that I need to get a tuner and get it dynoed?? So I have done some research on the web and see that some people say you can get a tuner and not Dyno it and others say you need to do both. What exactly is a tuner? Any recommendations for the setup I have? I will eventually be adding some cams but that's about as far as I will be going.
2012 RG FLTRX MGS pipes, 21" HogPro Vivid Black Shelby w/LRB rotors, KW Wrapper Fender,Mustang wide tripper solo, PY 14" monkey bars, CD plasma rods
Jasondoow is offline
post #2 of 8 (permalink) Old 05-05-2013, 12:23 PM
TRUBlue's Avatar
Since you're running a Dragula, I'd say call Frank at Dragos, gives good advise, active here too. A lot depends on what's next. For me, the Thundermax offered the most options for future mods with auto tune. Costs about the same as a tuner and a couple of dyno sessions.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #3 of 8 (permalink) Old 05-05-2013, 02:17 PM
PFWiz's Avatar
Yep, call Frank, He can provide with both tuner and a map customised for your rig.
PFWiz is offline
post #4 of 8 (permalink) Old 05-05-2013, 03:08 PM
crossbonesglide's Avatar
A tuner is basically a key that allows a person to change the fuel maps stored in the ECM. The program uses a dyno to adjust the fuel map for your bike! An auto tuner or canned map is a fuel map made from someone else's bike. Your bike can run properly but it might not be the best tune. If you plan on cams, buy a the tuner of choice your mechanic recommends.
crossbonesglide is offline
post #5 of 8 (permalink) Old 05-06-2013, 08:07 AM
piggs's Avatar
Exactly my questions, Jason. Thankyou for typing it for me...
Will be calling dragos today. one other question. can harley void my warrantee if i were to install the dragos items?. I'll hang/look around for more answers.. i feel like such a nubie.
Piggs, SemperFi
2013 FLTRX Denim
piggs is offline
post #6 of 8 (permalink) Old 05-06-2013, 08:19 AM
93-331-29psi's Avatar
Piggs, Dealer can not void your warranty unless they can prove that your modifications are the cause of the failure (if and when a failure happens).
93-331-29psi is offline
post #7 of 8 (permalink) Old 05-08-2013, 11:49 PM
There are a number of cost effective tuning products that will give you good results without putting your bike on a dyno, for just doing pipes and a/c.
'Had a V&H FuelPak on my '09 SERG when I bought it, it was great (especially at the $ point)
FuelMoto (Power Commander) is really good with their "canned maps"
Frank should be able to hook you up without spending a lot of $ (a canned map in an "entry level" tuner)
You really only have to go to the next level of tuners (and dyno) when you change other things like cams, heads, adding compression etc...
Don't be shy about an "entry level" tuner, if down the road, you choose to do more mods, you can always sell them. (I went with bigger cams & H/C pistons 'had the FuelPak sold before I took it off of the bike)
HeatWave is offline
post #8 of 8 (permalink) Old 05-09-2013, 01:12 AM
Q-Hog's Avatar
Great advice..
Q-Hog is offline
What questions to ask of a Dyno Tuner? Hullhorr Dyno Results 3 12-13-2012 02:02 PM
Advise on dyno tuner & engine builder needed neuropac Engine Related 7 11-16-2012 10:18 AM
KY people: dyno/tuner help, please!!! WoodyHD ECM/Fuel Management systems 6 06-09-2012 07:38 AM
2 into 1 with no tuner or dyno? Swagzilla Intake and Exhaust 16 01-23-2012 05:43 PM
Good Dyno Tuner in Denver? RockyMtnRG *General Road Glide Discussions/Pictures 7 12-03-2010 10:28 AM
