SERT Dyno Tuning Issues - Road Glide Forums
post #1 of 16 (permalink) Old 05-06-2013, 05:19 PM Thread Starter
Question SERT Dyno Tuning Issues
In December 2012, I purchased a package deal from my local HD dealer for my '12 FLTRU. They installed SE255 cams, SE high volume oil pump, FuelMoto 2-1-2 head pipe, CFR slip-ons, and SE Ventilator. The SERT was part of the package deal with all the upgrades. After everything was installed I drove the bike and it ran horribly. I promptly took it back to the dealer and they agreed to re-tune the bike. Second time I pick up the bike, I get 100 miles almost to a full tank of fuel. I took it back again. Third time I take it for a drive after they re-tuned it and the bike runs the best of the 3 yet I have an issue with it lagging in 6th gear. I take the bike back a 4th time, for the lagging. I was "convinced" by FuelMoto and the dealer that the CFR slip-ons where causing the problem. I ordered FuelMoto 4" Jackpot Dyno-Tuned slip-ons, installed them myself, then took the bike back to the dealer for it to be re-tuned a 4th time. I stupidly agree to pay $150 for more dyno time "since I changed out a part", even though the part was changed because it came recommended from FuelMoto and the dealer to fix this on going tuning issue. My bike runs slightly better after the 4th tune but still has lag in 6th gear, decel pop, and poor throttle response. I am looking for help in finding a technician locally that can dyno tune my bike and get her back to good health. I live in the Memphis, TN area. Any help would be great!
Thanks,
J
MrSmooth1031 is offline
post #2 of 16 (permalink) Old 05-06-2013, 08:24 PM
TLKurtz's Avatar
Send a message via Skype™ to TLKurtz
I can't help you with a local tuner to you, but I experienced the same issues as you. I basically spent 4 weeks with my bike in and out of the local dealership with them trying to tune it. They finally got it tuned, but the bike still runs like crap in 85+ deg. weather.
I have a local tuner I'm taking the bike to this Thursday to see what he can do with it. As a side note, I've heard the SE255 cams that I have (and you have) are not a great choice. Evidently they create roughly 175/lbs of cylinder pressure and 180/lbs is about the upper limit. Additionally I was told that the 254 cams are a much better choice. I don't build v-twin engines, so I don't know how accurate all of that is. We will find out this week what can be done with my current setup.
Meanwhile, I do believe a good tuner can get your setup running well for you. I hope somebody else can chime in and help you out. Please keep us updated.
-TLKurtz (Mr. Wizard) - Blackhorse Cavalry Nomads VMG member (2/11 CAV - East/West German Border)
2015 RGS - Vivid Black and loads of fun.
Reside in Vegas. I keep cold beer in the fridge for all visitors.
TLKurtz is offline
post #3 of 16 (permalink) Old 05-08-2013, 11:18 PM
I think that both of y'alls problems are with the tuners at your dealers.
Both the SERT and the 255s are well liked by a lot of people.
Y'all just have to get 'em dialed in.
HeatWave is offline
post #4 of 16 (permalink) Old 05-08-2013, 11:28 PM
ammojeff's Avatar
Ill found out in a few weeks how that setup goes, I have CFRs, will have new V&H true dual headpipes, big sucker, 255 cams, adjustable push rods, SERT and will auto tune initially then dyno it.
AMMO: Giving the enemy the opportunity to die for their country
ammojeff is offline
post #5 of 16 (permalink) Old 05-09-2013, 12:20 PM
I would recommend scraping the SERT and putting in a Thundermax auto tuner then there won't ever be a need for a dyno tune again. I have had the same problems with dyno tunes and mostly it is the man doing the work that is the problem, these people either don't take the time or don't know on how to correctly adjust the timing and AFR.
post #6 of 16 (permalink) Old 05-09-2013, 01:16 PM
GoodmanHD's Avatar
+1 on Ironmark's suggestion. I prefer the PC5 but most likey the guy doing the tune is the problem. With a lot of tuners it seems to be a PICNIC...Problem in Chair, Not in Computer! I'd recommend taking a ride down to my neck of the woods and having Gary Williams dial it in! And go to Tico's while you're here!
-GOODMAN
08 SHARK
96 HERITAGE
96 WIDE GLIDE
94 ROAD KING
IF EVERYTHING IS UNDER CONTROL, YOU'RE GOING TOO SLOW!
GoodmanHD is offline
post #7 of 16 (permalink) Old 05-09-2013, 02:26 PM
rcdifalco's Avatar
The SERT is not the problem, it's the dyno tech. I have a simelar set-up with 255's, V&H haeder and 4" slip-ons, and my bike runs great. The dyno terch's are a common problem, apparently they are not trained very well.
rcdifalco is offline
post #8 of 16 (permalink) Old 05-09-2013, 03:47 PM
TLKurtz's Avatar
I'll find out. My scoot is at Flora Racing Heads in South Bend (you can find them on Facebook or do a Google search of that or Jeff Flora). In our area Jeff is the man when it comes to Harley's. Lots of accolades in the racing community, builds his own heads, etc. etc. He claims he doesn't like the 255's NOT because they can't be tuned, but because they create too much cylinder pressure and other cams in the same setup will make more TQ & HP with less cylinder pressure. A little beyond my scope of knowledge, but given his experience I trust him. I'll post the dyno sheet and results when he is done. I'm sure most of my problem is the lack of tuning experience at the dealership.
I would love to go with the Thundermax, but I don't have the right exhaust setup and I'm not hip on the idea of cutting and welding on this exhaust. I've already spent the money on the current setup to it is water under the bridge per say.
What are your TQ & HP numbers so I (we) have something to compare to?
TLKurtz is offline
post #9 of 16 (permalink) Old 05-09-2013, 03:57 PM
McLuvin's Avatar
Mrsmooth,
Im here in Memphis so I can guess which dealer you are refering to. The new shop Leatherwoods down off Broad is getting a new Dyno and is advertising it heavily. Luke the owner was talking it up at the Wild Hogs poker run several weeks ago. Might be worth a shot. Other than that the guy referd to above outside of Jackson is very well spoken of here on the forum. When i do my next round, it will probably be done there. Hope you get it worked out.
excuse me while I whip this out...
McLuvin is offline
post #10 of 16 (permalink) Old 05-09-2013, 04:58 PM
If you don't want to weld in 02 bungs for a Thundermax then you can always order the 2009 head pipe from Fuel Moto and sell the head pipe you have now.
The 2009 head pipe will fit your bike and it has the 18mm 02 bungs in the proper place to install a auto tuner.
I used the SERT on my bike for years and never had any problems but when I made performance changes I couldn't get a good dyno tune anywhere thats when I decided on the Thundermax auto tuner and once I put that on my problems went away and the bike ran better then ever.
Tags
dyno , fuel moto , race tuner , tuner
Dyno Tuning in NY Joe.stevens101 ECM/Fuel Management systems 3 05-21-2016 07:34 PM
Smart tuning after a dyno tune x52gnr ECM/Fuel Management systems 1 09-07-2012 08:56 AM
SERT Tuning Problem swampking ECM/Fuel Management systems 6 04-15-2012 09:50 PM
08' W/True Duals/SERT/Ness Big Sucker Defy Dyno Results 5 04-28-2011 06:15 PM
Dropping a map into a SERT BigDaveOnBass ECM/Fuel Management systems 0 02-28-2011 07:52 AM
