Auxillary fuel cell - Road Glide Forums
post #1 of 3 (permalink) Old 12-29-2017, 03:50 PM Thread Starter
Auxillary fuel cell
I currently run a 5 gallon auxillary tank, gravity fed to a T at the front of my tank.
From what I'm reading everyone says that you can't do that with fuel injection because of a pressurized tank.
I'm confused as I'm currently doing it.
Hutch is offline
post #2 of 3 (permalink) Old 12-29-2017, 04:51 PM
Thermodyne's Avatar
The tanks aren't pressurized, but they are sealed. On late scooters venting the tank will set a code.
Not sure what flavor of scooter were talking about here, so I can't comment on the tee at the front of the tank. But on later scooters, if the spare fuel is above the level of the existing tank vent valve, there is a huge risk of venting fuel through the canister.
Now I gotta ask, why do you need all of that fuel?
Thermodyne is online now
post #3 of 3 (permalink) Old 12-29-2017, 05:56 PM Thread Starter
The continued quest to ride farther without stopping...
Also just picked up a sidecar rig and looks like it's only going to get 25 to 28 mpg
Hutch is offline
LED / Auxillary Lighting RichardTL Aftermarket Accessories 3 10-29-2015 11:28 AM
Cell Buckle - Cell Phone Mount FireGuy88 Aftermarket Accessories 39 07-21-2013 07:34 PM
Best Auxillary Lights/What are you using? CSM11 Lighting 22 04-03-2013 06:09 PM
Auxillary Lighting bacchus9876 Lighting 14 11-16-2012 09:01 PM
No auxillary back light and fast blinking turn signal nathancromer Lighting 5 10-01-2012 07:23 AM
