HD tuner/zippers/PC-V - Road Glide Forums
post #1 of 31 (permalink) Old 12-04-2010, 12:37 PM Thread Starter
Seems to be alot of pro's and con's. I have the PC-V now. Seems to work good. I'm doing a stage three, and wondering if I need to change.
RoadGlide0611 is offline
post #2 of 31 (permalink) Old 12-04-2010, 02:34 PM
Wooden Nickel
Guest
Posts: n/a
I've had a PCIII on a stage III build for years and it works just fine. Not one bit of trouble.
post #3 of 31 (permalink) Old 12-04-2010, 06:02 PM
roadgliderick's Avatar
Send a message via Yahoo to roadgliderick
everytime u make a change pipes cams and so on u need to dyno. i went through all that i finaly bought the thundermax TBW i dont have dyno any more the ecm learns on its own. right now i have true duals free flowing breather i down loaded the closet map and the bike runs great. my next move is cams when i do the cams i find the closes map and down load it and iam done. if wanna do a 110 motor i find the closes 110 map down load it and ride it as u ride the bike it will self tune to your specs. read the fuel moto write up how he said he installed one and he change the AFR s on purpose only for thew thundermax to adjust on its own. he put that bike on his dyno machine and it was very close to as if it were dynoed. jamie his self said he very impressed the new thundermax TBW. i bought and iam glad i did. they sell for pretty close to a $1000.00 bought mine from eastern performance for $800.00 shipped. best $800.00 i have ever spent.
Rick
2011 roadglide firemist orange carlini 17 inch eval bars, C&C solo seat, paugho true duals with thunder header slip ons , oil bud oil cooler, cool sac grips, alpine cda 105 head unit, alpine type r speakers with alpine 2150 digital amp,stratum timer cover derby cover and a/c cover sinister wheels 21 up front 18 rear woods 555 cams with adjustable push rods and tmax tuner. bad dad front wrap and bad dad rear summit fender with hide-a-plate and flush mount rear LEDs arlen ness big bags.
roadgliderick is offline
post #4 of 31 (permalink) Old 12-04-2010, 07:45 PM
Carisma Audio's Avatar
You purchased your thundermax for that thats awesome could you post there contact info
Carisma Audio is offline
post #5 of 31 (permalink) Old 12-04-2010, 08:11 PM
www.easternperformance.com if i were u i would call them and ask them about the thundermax TBW and have your credit card ready you gonna love this thing it is awesome. good luck to ya
Rick
post #6 of 31 (permalink) Old 12-05-2010, 10:23 AM Thread Starter
Are the zippers married to the ecm? Can you buy a used one?
post #7 of 31 (permalink) Old 12-05-2010, 10:32 AM
no the thundermax is your ECM
post #8 of 31 (permalink) Old 12-05-2010, 10:39 AM Thread Starter
Ok, so the thundermax is an ecm. So, you take your ecm out, and replace it with this?
post #9 of 31 (permalink) Old 12-05-2010, 10:48 AM
thats correct depending on your year bike if u have a 2010 or 2011 u have the small 11mm 02 sensors. thundermax requires wide band 02 sensors which are 18 mm so will have to weld the bigger ones on your head pipes.in order for the thundermax to work on your bike. if have a 08 to 09 you wont have to anything but install it very simple to do. u will not be disappointed if u buy it.
Rick
post #10 of 31 (permalink) Old 12-05-2010, 12:01 PM Thread Starter
I appreciate everyone's input. So, by some of the responses. zippers is the best?
HD Screamin Eagle Ventilator vs. Zippers Max-Flow twistr Intake and Exhaust 7 11-08-2013 11:23 PM
Tuner Super Sale Save big $$$ on Dynojet PV, PC-V, Thundermax fuelmoto Fuel Moto 0 09-03-2013 10:01 AM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 10:00 AM
PC-V with Auto Tuner problem RoadGlide0611 ECM/Fuel Management systems 7 05-03-2011 06:50 AM
