If you go with bigger injectors you will need the 58mm throttle body. IMO you will get better performance with the stock injectors and TB especially on the low rpm power band. I had a 103 big bore stage 4 in my bike with the 58mm TB and the bigger injectors and I wasn't happy with the set up so I went back to the stock setup. JMO
