Thundermax help - Road Glide Forums
post #1 of 4 (permalink) Old 05-15-2013, 01:39 PM Thread Starter
Thundermax help
Hey guys couple of questions in the Thundermax tuner. I seem to get a ping about 3800RPM till about 4200RPM. So I have been reading and doing some research and other people say to check the AFR setting and make sure they are between 13.6-13.7. So in the Auto tuner settings is that the Target AFR setting I'm looking to verify and tweak? God I hate Pinging. Thanks
Tofast4u is offline
post #2 of 4 (permalink) Old 05-15-2013, 02:01 PM
13.6 to 13.8 AFR is in range. Did you do a data collection and send it along with a description of your problem to T-Max support. To me it sounds more like a timing issue not a AFR issue and T-Max has a proceedure to set your "timing vs engine temp" .
post #3 of 4 (permalink) Old 05-27-2013, 01:21 PM
marksking's Avatar
Take a sample and send it off to Zippers, they have been very helpful in helping me with mine. They may even send you a correction to download.
marksking is offline
post #4 of 4 (permalink) Old 05-27-2013, 07:25 PM
TRUBlue's Avatar
I had the same issue, they told me to retard the timing 1 degree. As someone else said, send them data to analyze, they'll make recommendations.
Also make sure you have the latest firmware, you'll need to be connected to the Tmax and have an internet connection to download.
Try this site if you haven't already, there are a few video clips demonstrating tweaks. http://www.thunder-max.com/Support/I...ionVideos.aspx
'12 FLTRU Big Blue Pearl
TRUBlue is offline
help with Rinehart Thundermax griswold ECM/Fuel Management systems 6 01-08-2015 09:01 AM
Thundermax map to help fuel economy?? 1BadGlide Map Section 8 07-03-2014 09:56 PM
Need Help with Thundermax autotuner AFR settings Tofast4u ECM/Fuel Management systems 3 06-06-2013 02:40 PM
Thundermax impression Rowdy ECM/Fuel Management systems 9 11-23-2010 09:27 PM
Zipper Thundermax Ranger58 ECM/Fuel Management systems 12 11-19-2010 10:26 AM
