Error Code U1016 Loss of ECM Serial Data - Road Glide Forums
post #1 of 7 (permalink) Old 05-15-2013, 04:33 PM Thread Starter
Q-Hog's Avatar
Has anyone experience a Diagnostic Error Code U1016, Loss of ECM Serial Data? If so, what's the cause and corrective measure? Thx.
Q-Hog is offline
post #2 of 7 (permalink) Old 05-15-2013, 04:36 PM Thread Starter
Q-Hog's Avatar
Please place in correct forum. Thx..
Q-Hog is offline
post #3 of 7 (permalink) Old 05-15-2013, 05:04 PM
Mike U's Avatar
That's a loss of serial data.
Fuel Moto has a post on their site about Harley Codes and how to reset them.
Harley Codes - Fuel Moto
Hope this helps.
Best of Luck.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #4 of 7 (permalink) Old 05-15-2013, 05:19 PM
Mike U's Avatar
Q-Hog from what I've been reading people are saying that the Thunder Max is causing it.
By chance, are you also running a Thunder Max on yours?
If so, I believe Thunder Max states there's nothing to worry about it's just the difference in the ECM and The Thunder Max.
Mike U.
USMC 1975-1977
Semper Fi!
Mike U is offline
post #5 of 7 (permalink) Old 05-15-2013, 08:00 PM Thread Starter
Q-Hog's Avatar
Thx. I am running TMax.. I heard something regarding that but I wanted to see what the great minds of the Tank had to offer.. Can't beat what this forum has to offer..
Q-Hog is offline
post #6 of 7 (permalink) Old 05-16-2013, 11:19 AM
It most in likely not the T-Max. I would suggest changing the battery in your FOB. When the ECM doesn't read the FOB correctly because of a low battery then you will lose serial data and get the code U1016
post #7 of 7 (permalink) Old 05-16-2013, 11:29 AM Thread Starter
Q-Hog's Avatar
Thx guys.. I will check it.. Thx
Q-Hog is offline
Powervision ECM Data Piraterider ECM/Fuel Management systems 0 04-25-2017 09:17 PM
Error code question or at least I think it's an error code wvdave Troubleshooting for Road Glides 1 07-15-2015 10:21 AM
Error Codes on TMax Diagnostic Code Page Q-Hog ECM/Fuel Management systems 4 06-30-2013 11:58 AM
Found an error code any idea what it means? Dmize Troubleshooting for Road Glides 5 01-15-2013 02:33 PM
tts mastertune error code 502 pimpsarus ECM/Fuel Management systems 8 10-21-2012 10:29 AM
