S&S T124lc which tuner do you use? - Road Glide Forums
LinkBack Thread Tools
Old 02-19-2018, 04:45 AM Thread Starter
I am in the middle of swapping out my 103 for a T124lc crate motor in my 2013 FLTRU. One of the last things to do is select a tuning module.
I have an SE tuner. Newer one not SERT. My mechanic wants to use a Thundermax with wide band O2 sensors and auto tune. I originally wanted to switch to a TTS. Of course there is also the PV with auto tune and wide band sensors.
My question is which one do you guys with the 124s run? Are you happy with the choice?
I want to get this right. I like the sound of ease of use the TMAT provides. I live in Denver so altitudes change rapidly and I make runs to sea level.
I have read about the TM ECM not having a knock sensor. Apparently that need is minimized by the adjustability of the TMAT. Plus the S&S is a different animal than the TC103.
Running the following:
S&S T124lc
Dragula 2:1
HPi 58mm elliptical TB throttle by wire
Matched injectors
Any insights are greatly appreciated.
CORGU2169 is offline
Old 02-19-2018, 01:36 PM
Kevsbigred's Avatar
I like the PV myself
But you are going to have you post some videos of that thing. Iím waiting to hear how it sounds!!!!
Kevsbigred is offline
Old 02-19-2018, 03:02 PM
Thermodyne's Avatar
Thunder Max any day of the week, 24-7-365. I wouldn't worry to much about the lack of knock sensing, that Delphi ion sensing system is so friging bad to begin with, it might as well not be there. And it is not hard to work with the timing pages on the TMax.
If I was feeling like taking on a new learning curve, then I would play with the TCFI Gen 6 Fuel Injection Controller from Daytona Twin Tech. Mostly cause I want to try the Bluetooth connection out for live data. It's Alpha-N just like the Tmax, but it's also supposed to have a newer/better tuning interface.
Thermodyne is offline
Old 02-19-2018, 04:31 PM Thread Starter
Thanks Thermodyne. My guy mentioned timing maps so glad to have separate confirmation.
KevsBigRed, as soon as she gets her initial 50 mile break in on the dyno I will see if I can post a video with sound. Should be pretty nice.
Old 02-19-2018, 04:35 PM
mastergunnera8's Avatar
Wow, Cant wait to see/hear that!! Personally I'd go with whatever my tuner/Mech recommended...Good luck!!! hope you have a rider backrest!!!
mastergunnera8 is offline
Old 02-19-2018, 06:49 PM
Thermodyne's Avatar
It's not hard at all to rework the spark pages. Here's the how to:
http://www.thunder-max.com/techdocs/TimingVsRpm.pdf
Old 02-19-2018, 07:11 PM Thread Starter
Lol. Thanks Mastergunnera8. I do have one. Don't need my arms lengthened any more than they are. Knuckles are already draggin',,
Old 02-19-2018, 07:31 PM
There was a thread on the tech forum from a guy living/riding in altitude, don't know if that was you. A lot of those guys are tuners and have tuned a lot of bikes. If you are confident in the guy you select to tune your bike, go with what he likes to use
phillyfan1 is offline
Old 02-19-2018, 11:40 PM
Kevsbigred's Avatar
Corgu. Is that the dragula 1 or 2 pipe
Old 02-20-2018, 07:26 AM
09 YELLOWBIRD's Avatar
I have a very well built SE 117" Pro Race Motor, from a Dark Horse worked Crank, Head Work by Don at HDSP, aftermarket Cams, lifters, Springs, SE 58TB with 5.3 injectors, Drago's Dracula II 2-1 pipe and TTS Turner.
My Rig runs pretty damn good, So Damn Good that my best Bro who dropped a stock S&S 124LC hated the fact that I could pull away and could not catch me!!!
Well those day are well over as for now. All I can see is his Tail Lights!
His S&S 124" ended blowing out some blue smoke. Still under warranty, he had it fixed my Zack at KJC. THEN comes the other goodies. Custom CP Pistons, CNC Heads, swapped out SE 58TB for a HPI 62TB, changed 2.55" baffle fr the 3.00" baffle in his Drago's Dracula II 2-1 Pipe. Zack Tuned via PV.
Although the Dyno is in "STD" vs "SAE", 154HP & 147TQ. Its still a BEAST!!!!
OP- just saying for a little bit more $$$ you could also have a Fire Breathing Dragon!!! Either way, a S&S 124" motor is the Chit, Real Power for Real Touring out of the box!
Good Luck with your Build.
YB
2009 SCREAMIN' EAGLE CVO ROAD GLIDE FLTRSE3 117" PRO RACE
(1 OF ONLY 369 U.S.) "LAST YEAR OF THE HAND BUILT"
09 YELLOWBIRD is offline
Which do you use more? Front Brakes or Back? turbochrisb *General Road Glide Discussions/Pictures 41 09-18-2017 11:38 AM
*Which Pistons?? Which Tuner??* HELP! Iron1 Engine Related 2 02-08-2017 07:15 PM
S&S T124LC Dyno Results Pablo22 Dyno Results 22 09-07-2015 01:36 PM
Bright Ass Lights (BAL-1R). Which Mode Do You Use? REDRUM Lighting 15 04-08-2014 06:37 PM
