Need Some Help with DynoJet AutoTune Install - Road Glide Forums
post #1 of 5 (permalink) Old 03-01-2018, 11:03 PM Thread Starter
Started installing a PC5 and AutoTune on my 2013 RG. I have the wide band O2 sensors installed in the header but stuck with where to run the wire and where these should be mounted - if at all.
Would love to hear from anyone who has installed these before.
Thanks!
2013 Road Glide
Pretty much stock - for now
klinkster74 is offline
post #2 of 5 (permalink) Old 03-02-2018, 09:49 AM
norm9278's Avatar
If the PC5 doesn't have a connector for them one could assume (yeah) that they would plug into the harness in place of the old O2 sensor. Dunno, but makes sense to me if the instructions don't say.
norm9278 is offline
post #3 of 5 (permalink) Old 03-02-2018, 10:02 AM
Thermodyne's Avatar
On my Tmax, I ran the harness back under the end of the starter and then up the frame tube to the connector behind the right panel. No ties till it got to the frame tube. But the harness was a lot longer than that one looks to be.
Thermodyne is offline
post #4 of 5 (permalink) Old 03-02-2018, 11:05 AM Thread Starter
There is another wire that plugs in to it, the one for the front is really long and the is short so there is lots of wire to route it any where. The fact that it has some nice plastic mounting plugs kind of threw me as I can find the holes to push them in to.
So you did use them and used tills along g the frame. Simple enough. Thanks so much!
Stephen
Ontario Canada
2013 FLTRX
2013 Road Glide
post #5 of 5 (permalink) Old 03-02-2018, 11:30 AM
Thermodyne's Avatar
The sensors are usually just repackaged automotive parts. TMax uses sensors from a VW. So the push pin on the side of that connector is prolly for another application.
AutoTune Instructions For Dynojet Power Vision fuelmoto Fuel Moto 0 08-08-2018 04:42 PM
Dynojet autotune for powervision 200.00 pat123 Parts for Sale 2 09-22-2014 04:18 PM
Dynojet Powervision,Autotune pro and Iron Aces road glide mount pat123 Parts for Sale 5 09-11-2014 11:16 PM
Need some help with cvo fascia install stang9986 Paint & Bodywork Section 23 09-04-2013 02:30 PM
Dynojet AutoTune AT-100B jokercraze Classifieds Archive (3 months old+) 0 08-05-2012 10:07 AM
