Power Vision Auto Tune - Road Glide Forums
post #1 of 7 (permalink) Old 05-22-2013, 08:58 PM Thread Starter
Deno172's Avatar
How long should a normal Auto Tune ride go for. Also is it normal to get red and orange squares on the Auto Tune graph screen?
Deno172 is offline
post #2 of 7 (permalink) Old 05-22-2013, 09:07 PM
LL Cool K's Avatar
It's not about length of ride... you want it to fill out all of the graphs through all the throttle ranges and rpm. You'll have to ride it pretty hard to do it. Go out and have some fun!
2012 FLTRU, Vance & Hines Power Duals, Fuel Moto Jackpot 4" Slash Ups and Air Filter, Power Vision
LL Cool K is offline
post #3 of 7 (permalink) Old 05-23-2013, 05:14 AM
RhinoHD's Avatar
Ok But any idea what the diff rent colors in the graph mean???
Life is good but it's not easy!
RhinoHD is offline
post #4 of 7 (permalink) Old 05-23-2013, 07:00 AM
Deadstroke's Avatar
Best way to auto tune is to do this.. ride it and get it warm then setup auto tune to start, hammer it through all the gears at then maintain a speed you are comfortable with for a min or 2 then ride home like you normally would for about 10 - 15mins in cruising and stop and go traffic. then pull over save the tune and flash and then ride it..
If you find hesitation or low spots run auto tune again, and ride where u had the issues and then repeat process till you are happy.
It took me a hour but I am dialed in very well and my mileage actually went up. If you just have pipes and air mods it wont take you that long at all. I just got done with cams so took a little more..
Deadstroke is offline
post #5 of 7 (permalink) Old 05-23-2013, 07:13 AM
mocotom's Avatar
The colors in the graph show you how many times the motor saw the rpm and load in that given cell. They change color as to the number of hits each cell gets. Red is fully populated and what you are trying to obtain.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 7 (permalink) Old 05-23-2013, 01:20 PM
RhinoHD's Avatar
Thanks Mocotom! Thats helps/
RhinoHD is offline
post #7 of 7 (permalink) Old 05-23-2013, 07:58 PM Thread Starter
Deno172's Avatar
Thank you all for your help.
Deno172 is offline
My Power Vision Auto tune results. LL Cool K ECM/Fuel Management systems 137 06-06-2017 05:15 PM
To auto-tune, or not to auto-tune Magnum ECM/Fuel Management systems 12 08-27-2014 06:25 PM
auto tune vs no auto tune Jacket4256 ECM/Fuel Management systems 18 06-01-2013 08:12 PM
Question 4 you Power Vision pro auto tune guys - kinda long landshark ECM/Fuel Management systems 2 03-12-2013 06:21 AM
Power Vision basic Auto tune or Pro? baldwookie ECM/Fuel Management systems 8 03-02-2013 09:15 AM
