Thundermax on a stock 2010 RGC - Road Glide Forums
post #1 of 19 (permalink) Old 12-09-2010, 11:38 AM Thread Starter
pab
pab's Avatar
Pardon me if this has already been discussed, but I've searched the various threads concerning the Thundermax, and couldn't find what I'm looking for. I'm hearing talk locally (Nashville, TN) that after installing a Thundermax on a totally stock 2010 RGC 96 engine you can expect a cooler, smoother running engine, with a lower rpm at idle, and little more zip when accelerating. Any comments / testimonials, pro or con, will be appreciated.
2010 RGC. Madstad, Heritage bars with chrome levers, detachable tour pack with LED lighting, Ventilator AC, Vance and Hines Power Dual header, CVO mufflers, SERT Pro, Progressive HD rear shocks, and several other odds and ends.
pab is offline
post #2 of 19 (permalink) Old 12-09-2010, 02:49 PM
probably pretty accurate. I have heard via the internet (so it has to be true cause no misinformation could possible on the internet) that the cats can get damaged from being too rich. I would like to know for sure tho.
jeff is offline
post #3 of 19 (permalink) Old 12-12-2010, 09:59 PM
roadgliderick's Avatar
Send a message via Yahoo to roadgliderick
i have a 2011 roadie with true duals stage 1 a/c with CFRs befor that rineharts. my motor went from smokin hot to i cant feel the heat any longer yes it does idle a little lower 950 rpm and alot better throttle response and start ups are great hot or cold.alot more torque. the best $800.00 i have spent on my bike should u decide to buy one i would suggest www.easternperformance.com $819.00 with free shipping . hope this helps.
Rick
2011 roadglide firemist orange carlini 17 inch eval bars, C&C solo seat, paugho true duals with thunder header slip ons , oil bud oil cooler, cool sac grips, alpine cda 105 head unit, alpine type r speakers with alpine 2150 digital amp,stratum timer cover derby cover and a/c cover sinister wheels 21 up front 18 rear woods 555 cams with adjustable push rods and tmax tuner. bad dad front wrap and bad dad rear summit fender with hide-a-plate and flush mount rear LEDs arlen ness big bags.
roadgliderick is offline
post #4 of 19 (permalink) Old 12-13-2010, 05:52 AM Thread Starter
pab
pab's Avatar
Thanks for your response roadgliderick. From what I've learned, the Thundermax is a very good product, but for the Thundermax to really make a difference, I will have to do what you've done....add to the package with new headers, muffs, AC and oil cooler. Guess my quest to get a better, cooler running bike by just adding the Thundermax to it in stock configuration just won't make a big diffrence.
pab is offline
post #5 of 19 (permalink) Old 12-16-2010, 08:38 AM
Deuce Bigelow's Avatar
for half of that price you can get the TTS MasterTune and accomplish the same thing.... you just won't have the "autotune" feature...
I had the Thundermax on my '06 Deuce AND my '07 CVO Springer... I took it off the springer and installed the TTS MasterTune and saw an immediate improvement!
my opinion would be to save your money......
2010 FLTRX
Deuce Bigelow is offline
post #6 of 19 (permalink) Old 12-17-2010, 10:59 AM
Is the TTS easy to use?
RoadGlide0611 is offline
post #7 of 19 (permalink) Old 12-18-2010, 12:16 PM
then i guess u havent tried a thundermax lately cuz i have been through all the other tuners. with no sucess sinse i have installed the thundermax all my issues are gone and i save alot of money not having to dyno each time i make a change to my bike.
post #8 of 19 (permalink) Old 12-18-2010, 05:46 PM
if you used the TTS, you would know that there is no need to dyno.....
What tuners have you "been through" ?
I've been through the SERT, ThunderMax w/autotune, and the TTS.
based on my experience, the TTS has been the best one so far.
I don't think the ThunderMax is worth $800.00, not when you can get the same if not better results from the TTS Masterune.
2010 FLTRX
post #9 of 19 (permalink) Old 12-18-2010, 09:53 PM
u know what they say about opinions. to each is own just like u said u like the tts good for u i like the thundermax i could afford it so i bought it. best $800.00 i have spent. i guess u havent got any tuners either is that your reason for buying the tts what ones have u been to.
post #10 of 19 (permalink) Old 12-18-2010, 10:31 PM
as long as you're happy with it, that's all that matters.
I haven't dyno'd my bike, no need with the TTS tuner.
2010 FLTRX
For Sale: Lots of stuff from/for 2013 RGC or RGC CVO Methos1979 Parts for Sale 15 05-17-2015 12:22 PM
Added and 11 CVO RGC Ultra instead of a 15 RGC lh4x4 *General Road Glide Discussions/Pictures 11 07-14-2014 09:21 PM
2014 Thundermax units in stock and shipping at Fuel Moto fuelmoto Fuel Moto 5 02-01-2014 10:48 PM
WTT: Stock RGU Seat for Stock RGC/Street Glide Seat JayKS Parts for Sale 12 10-23-2013 12:03 PM
2010 RGC w/96 in Vivid black trade for 2011 RGC w/103 Sedona orange? bmayy71 *General Road Glide Discussions/Pictures 13 06-20-2011 04:54 PM
