Throttle lag. Power Vision and/or Throttlepak? - Road Glide Forums
post #1 of 27 (permalink) Old 05-23-2013, 12:51 PM Thread Starter
elbohead's Avatar
The first gear throttle lag on my 2012 FLTRX is driving me crazy. While searching for solutions, i've read that the V&H Throttlepak does a great job of eliminating this issue. I've also read that this can be addressed using a Power Vision tuner. Here is my dilemma. I already own the PV and though I've read that it can correct the lag, I've been unable to find exactly what needs to be done. I'll go ahead and buy the Throttlepak if I have to, but I'd hate to spend the money only to find out that I could have just used the PV in the first place. And, lastly, if I do end up with a TP, will there be any issues running it along with the PV?
TIA.
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
post #2 of 27 (permalink) Old 05-23-2013, 02:17 PM
I have limited insight on this but was actually wondering the exact same thing before I ordered my PV. When I talked with Brian at Fuel Moto, he advised that the map they would include would already have the throttle adjustment to a 1:1 ratio.
However, if you are still having the same issue, I'm now wondering if the throttlepak wouldn't make it even better. Curious what you find out.
Also, I just got my PV today so I haven't hooked it up yet to see if there is a difference.
Halstem1 is offline
post #3 of 27 (permalink) Old 05-23-2013, 03:12 PM
Following...
habu_sake is offline
post #4 of 27 (permalink) Old 05-23-2013, 03:33 PM
faststan's Avatar
You can run the autotune on the PV to tune out issues. If your PV doesn't have autotune you can get a firmware update to add it. No reason to buy another tuner...... You can go to Powercommander website to get a video for autotune....http://www.powercommander.com/downlo...utotune.01.pdf
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #5 of 27 (permalink) Old 05-23-2013, 03:43 PM
Pretty sure auto tune won't correct throttle lag in throttle-by-wire bikes.
Halstem1 is offline
post #6 of 27 (permalink) Old 05-23-2013, 03:47 PM
faststan's Avatar
If any other tuner will then autotune will also.
faststan is offline
post #7 of 27 (permalink) Old 05-23-2013, 03:55 PM
Torquey's Avatar
The V & H ThrottlePak, which works wonderfully by the way, is not a tuner. It addresses the opening of the fuel injection "butterfly" at a much faster rate of speed on TBW bikes, and that only. It does one thing, and it does it very, very well indeed.
Torquey is offline
post #8 of 27 (permalink) Old 05-23-2013, 04:13 PM
Autotune only makes adjustments to the VE table, not the butterfly speed. And not all tuners are capable of adjusting throttle speed.
Halstem1 is offline
post #9 of 27 (permalink) Old 05-23-2013, 04:36 PM Thread Starter
elbohead's Avatar
Torquey, I'm assuming that because it connects at the throttlebody and not the diagnostics port there won't be a problem running it along with the Power Vision?
elbohead is offline
post #10 of 27 (permalink) Old 05-23-2013, 06:19 PM
my throttle lag was gone when I installed the PV last week, not sure what settings were set in the tune provided, but it was night and day before and after
2013 RGU, black of course....
y2kflhr is offline
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
WTB: Vance and Hines FuelPak and ThrottlePak blj9511 Wanted! (Buy or Trade) 2 03-15-2013 07:23 PM
Throttle lag? jeffb928 Equipment-RG 20 12-05-2012 08:13 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
