“Close” canned PV tune safe enough for new cams? - Road Glide Forums
  • 1 Post By Dice21
post #1 of 2 (permalink) Old 03-28-2018, 06:40 AM Thread Starter
mchad's Avatar
Hi all.
I’m having Feuling 543 cams, lifters and a SE high flow oil pump/cam plate installed in my ‘16 Special - should be done today, get to ride home in the rain, YES! Guess that’s better then snow...
Anyway, I have a PV from FuelMoto, with a tune provided by them for my stage 1 setup - their E-series 2:1 pipe and HD heavy breather elite AC. The tune was excellent out of the box, and was able to squeeze a little more on a dyno.
So I asked Jamie for a tune for the pipe and AC, adding the Feuling 543’s. I also send him the full cam specs. He sent me back a tune he said should be “close” as he never tunes with those cams before.
I’m wondering (actually my OCD/paranoia is wondering) if that’s safe enough to ride for a while. It may be a month or so until I get her on a dyno. I’ll autotune a half dozen times or so, but that only does so much.
Thoughts?
2016 FXDLS LED's, Wild1 Psycho bars, FuelMoto E-series 2:1 and PV map, Ohlins FKS-212's and HD764's, Night Dragons, Ultracool, Wards Fans.
2016 FLTRXS LED's, Factory 47 12" Malo bars, FuelMoto E-series 2:1 and PV/Dyno refined map, Ohlins FKC-102 and HD357's, E-Z brake, LJ Fans. And a few audio improvements.
mchad is offline
post #2 of 2 (permalink) Old 03-28-2018, 11:11 AM
Dice21's Avatar
Those guys aren't going to send you something to use that's not safe for you to ride with. My guess is that his "close" is better than half the other guys "done".
That's only my opinion, and worth exactly what you paid for it. I'd run it till you can get to a dyno.
mchad likes this.
Dice21 is offline
FP3 canned map advice canukHD ECM/Fuel Management systems 6 05-16-2018 01:30 PM
Canned SE Map. What am I leaving on the table? bikepsych ECM/Fuel Management systems 11 04-04-2018 06:26 AM
Delta % from canned map after autotune Beaver Map Section 0 05-06-2017 05:02 PM
Close call. Real close! dreeves *General Road Glide Discussions/Pictures 38 04-25-2017 01:23 PM
Happy Canned Beer Day!!! OldNerdGuy General Off-Topic Discussions 11 01-24-2013 06:31 PM
