Thundermax map needed - Road Glide Forums
post #1 of 3 (permalink) Old 05-28-2013, 11:26 AM Thread Starter
spokanebagfan's Avatar
Have Andrews 57h, Dragula, thundermax, and screaming eagle heavy breather. What I do not have is the correct map. Please help. Bike is a stock 2012 custom. Thanks all.
spokanebagfan is offline
post #2 of 3 (permalink) Old 05-28-2013, 03:57 PM
Did you e-mail T-Max support for a suggestion? Since you have a 103 TBW you should try a base map that has a 2 into 1 exhaust with no cats. Contacting T-Max support is your best bet.
post #3 of 3 (permalink) Old 05-28-2013, 04:15 PM
TRUBlue's Avatar
What he /\ said but map # 188 looks close, shows D&D and "54h or similar".
'12 FLTRU Big Blue Pearl
TRUBlue is offline
Need map and have map to share Hack73 Map Section 0 10-03-2016 04:42 AM
Thundermax map to help fuel economy?? 1BadGlide Map Section 8 07-03-2014 09:56 PM
PC-V Base Map needed Hullhorr Map Section 0 10-22-2012 01:20 PM
PCV map for Andrews 48 needed FLTRU4ME Map Section 2 08-29-2012 10:35 AM
pc iii map needed 07 deluxe with 48cam bigpete1 Map Section 1 06-25-2012 07:53 AM
