auto tune vs no auto tune - Road Glide Forums
post #1 of 19 (permalink) Old 05-31-2013, 12:09 PM Thread Starter
Jacket4256's Avatar
Talking auto tune vs no auto tune
ok I am about to pull the trigger or my first major set of mods for the RGU, I am gonna do a:
PC-V
TW-222
Fuel moto head pipes, and other supporting mods.
My question is more on the auto tune is it worth the extra money ? also I really want something I can set and leave it, why I wanna go with PC over PV, but would the auto tune be worth extra money to run ? or can Fuel moto get a tune close enough with just the PC with map loaded that I would be ok, this will be it for the engine mods on the bike. I am not gonna go any further. I appreciate any input or suggestions.
2012 Road Glide Ultra
2011 Subaru OB
2006 GTO stock with idle problem
2004 Sporty that use to be a 883
Jacket4256 is offline
post #2 of 19 (permalink) Old 05-31-2013, 12:15 PM
If you're absolutely sure you're not going to do any more mods, the map will be right on target, and nothing else will change.......don't get auto tune, any doubt.....auto tune it is. IMO I'd go with auto tune.
post #3 of 19 (permalink) Old 05-31-2013, 12:30 PM
I got the PV so that I could play with the tunes myself easier than a tts, I got it with a great tune from FuelMoto, and then ran some auto tune runs, it is really simple to do once you get the hang of it, I am seeing a 1-2% change in the VE tables, now its getting hotter I would bet I will see even more of a change.
To sum it up, the PV gives you the ability to have a summer tune, winter tune, spring/fall tune, without much work so I recommend it over a plug and play system, and if you really don't want to use it, don't even mount it to the bars until you want to.
my 2 cents
2013 RGU, black of course....
y2kflhr is offline
post #4 of 19 (permalink) Old 05-31-2013, 12:42 PM
If you are absolutely sure that you are not going to make any more performance mods then a good aftermarket tuner or the SERT from HD will work fine with a good dyno tune. The cost of a good tuner and a dyno tune will be about the same as the cost of a good auto tuner such as Power Vision or Thundermax without the dyno. Remember if you decide on going with a auto tuner you will need head pipes for a 2009 model or a head pipe that has both the 18mm & 12mm bungs for the 02 sensors, the auto tuners require the 18mm 02 bungs.
post #5 of 19 (permalink) Old 05-31-2013, 12:44 PM
The pv basic auto tune uses narrow band (stock sensors)
y2kflhr is offline
post #6 of 19 (permalink) Old 05-31-2013, 01:17 PM
The Power Vision basic does use the stock 02 sensors but it isn't a true auto tuner. Using the stock 02 sensors the tuner is only capable of tuning the bike to the limitations of the stock HD ECM. The stock HD ECM with stock 02 narrow band 02 sensor can make small adjustment to the tune such as elevation change without a tuner. The PV basic tuner flashes the stock HD ECM and can make small changes that the narrow band 02 sensor will allow, if that tune doesn't work you will need to re flash with a new tune. PV sells the PV pro tuner kit which basically the wires and 18mm wide band 02 sensors which then turns the tuner in a real auto tuner. I have the Thundermax which is a true auto tuner and does not work with the stock ECM so it doesn't just FLASH your ECM like the PV does the T-Max replaces the factory ECM all together. With the mods the OP is doing the PV basic will work fine and then if other changes are made it would be easy to buy and install the PV pro package.
post #7 of 19 (permalink) Old 05-31-2013, 02:53 PM
Fuel motos map will get the bike running great, whether you go with a pc-v or pv. If you dont want to tinker, thats should work great. I had a pc-v with their map when I put on the exhausts. This year I added a 222 cams and upgraded to a pv with their map. Bike ran great! But I like to tinker so playing with the auto tune and gauges on the pv is fun. Running a few auto tunes I am seeing increased (slightly) gas mileage and bike runs great. My excuse for upgrading to he pv was the ability to clear and read trouble codes. Last summer on a trip in the ultra heat wave we had in midwest bike thew some codes that killed my speedometer-thus killing cruise. That really sucked on the highway!!
Its really up to how much you want to tinker. I think fuel motos preloaded maps will make you bike run 99 percent perfect. Adding an auto tune will bring it to 100 %. Whether that is even enough of a difference for anyone to notice is probably doubtfull. Either way your gonna notice such an improvement over stock you will be amazed!
Fuel Moto header (no cat) Jackpot 2 1/2 mufflers, PV by Fuel Moto, BAL1, Woods 222 cam
baldwookie is offline
post #8 of 19 (permalink) Old 05-31-2013, 03:52 PM
y2kflhr is offline
post #9 of 19 (permalink) Old 05-31-2013, 05:27 PM
mocotom's Avatar
Looks like you are basing all your changes around Fuel Moto's products and the Woods 222 cam that they sell. That is a smart way to achieve a good result, rather than mixing a bunch of parts that everyone swears are the best. By using their parts the map you will get from FM will be extraordinarily close if not spot on. The Powervision is by far the better tuning device, hands down.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #10 of 19 (permalink) Old 05-31-2013, 06:31 PM
Harleyagain's Avatar
Ya what he said
Bob
Harleyagain is offline
Stock vs Arnott vs Legends vs HD Premium SEsupply2 Suspensions 15 04-25-2017 10:10 AM
Thundermax vs DynoVision vs PwrPro Black vs FP3 stillsoldier4christ ECM/Fuel Management systems 16 10-01-2016 12:42 AM
To auto-tune, or not to auto-tune Magnum ECM/Fuel Management systems 12 08-27-2014 06:25 PM
PV: Ran Auto Tune NO Change in Map? RhinoHD ECM/Fuel Management systems 14 07-22-2013 11:52 AM
PCV Auto Tune vs Dyno ODA CDR (RET) Intake and Exhaust 2 10-05-2011 11:37 PM
