Harley street tuner and catless head pipe??? - Road Glide Forums
 4Likes
post #1 of 13 (permalink) Old 08-02-2018, 08:52 AM Thread Starter
Ok so I have spent 3 hours trying to find an answer. 18 rgu running with mk45, heavy breather, and Harley street tuner. I want to go catless only for the sound aspect. I miss the sound of my 103. I hate the way this bike sounds. So I hope removing the cat will make it sound mean again.
Can I run the harley tuner without a cat??
Sgt Goody is offline
post #2 of 13 (permalink) Old 08-02-2018, 10:53 PM
Dice21's Avatar
I can't answer your question exactly, but I can tell you this. Gutting the cat helps with heat. It will absolutely not make it sound like a 103. Nothing will. I have tried, and tried, and tried again. I'm embarrassed by the money I've spent looking for that sound. The M8 just won't sound like a 103.
I've got a gutted pipe and TABs with the Zombie baffles, S&S ac, and a FP3. It's the best sound I've found. But it ain't no 103.
madmat and sailorjerry13 like this.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #3 of 13 (permalink) Old 08-03-2018, 11:45 AM
BB Bomber's Avatar
Not an expert, but I believe you will need another tune when you remove the cat. The hd tuner should work just fine.
BB Bomber is offline
post #4 of 13 (permalink) Old 08-03-2018, 12:12 PM Thread Starter
I figured I won’t get that great sound but at least make it sound somewhat like a Harley. And thanks for the input. Guess I will have to have it dynoed.
post #5 of 13 (permalink) Old 08-04-2018, 06:15 PM
geo8866's Avatar
Anytime you change the air flow, you should retune with street tuner.
geo8866 is offline
post #6 of 13 (permalink) Old 08-04-2018, 08:08 PM Thread Starter
I have the stage one down loadex in the bike now. Do I need to do more??
post #7 of 13 (permalink) Old 08-05-2018, 11:05 PM
Dumb question. Doesn't it sound like a Harley when you buy it? After the mods, it no longer sounds like a Harley but something else.
CantRider is offline
post #8 of 13 (permalink) Old 08-06-2018, 08:11 AM
Dragon Dude's Avatar
Adding cams will make it sound better than most everything else.
RGKen and freedom1974 like this.
Dragon Dude is offline
post #9 of 13 (permalink) Old 08-06-2018, 08:49 AM
RGKen's Avatar
This^^^^^
If you remove the cat you will definitely need a new tune as it will run much too lean and the HD Street tuner will not allow you to richen it up enough because they only allow changes that stay within EPA compliance. It will also void your warranty even if it allowed for proper changes because it takes it outside of EPA compliance. You could run an aftermarket tuner but that can void your warranty also but I know guys are doing it with no problem so maybe someone can chime in on how they work that deal with their dealer.
The best way I feel, especially if you want to retain warranty, is to just upgrade to the SE Stage II torque cam and reflash to the factory MAP for that. It will make it sound better by giving it more of the Harley lope plus you will love the better throttle response and extra pull.
2018 FLTRXS
RGKen is offline
post #10 of 13 (permalink) Old 08-06-2018, 02:06 PM Thread Starter
Sounds like a good idea. I have been thinks ng of doing a can.
New stock catless head and slips/ do I need a tuner? MidniteRyder ECM/Fuel Management systems 10 02-17-2013 07:30 PM
Catless Head Pipe alyupe11 Classifieds Archive (3 months old+) 3 06-15-2012 09:28 PM
09 head pipe catless cestaro Classifieds Archive (3 months old+) 0 05-12-2011 05:49 PM
