PowerVision Blues - Road Glide Forums
 12Likes
post #1 of 30 (permalink) Old 08-27-2018, 05:52 PM Thread Starter
MightyWhitey's Avatar
PowerVision Blues
Has anyone used their Target Tune and figures theyíll never need it again? Just sitting on the shelf? Maybe we could work something out?
MightyWhitey is offline
post #2 of 30 (permalink) Old 08-28-2018, 05:07 PM Thread Starter
The reason for wanting to target tune
So....Iíve built a 110 and all is fantastic except for that little problem of being able to get someone competent with powerVision to tune it right. Iíll condense this story to the very short version. My usual tuner....crotch rocket and stage one harley, wasnít skilled enough tuning with kpa to make it work without adding a piggyback to trim-110hp 120tq felt amazing but too hot in the cruising area 275-280. Fast forward two months get some pinging in two spots on super hot days high load conditions. Go back to utilize my free retunes and he cleans it up comes out at 113hp 123tq but still HOT in cruise areas even after I asked him to cool that bitch down. Ran amazing though until I got stuck in Jackson,WY at a crap load of stop lights on a 90+ day then immediately climbed Teton pass and guess what, pingity ping ping ping. So I call my Pal Smarty and as always he had some advice for me and got me cooled down for the ride home and then I found what I thought was a competent PV tuner.....nope. Came out at 104hp and 115TQ(which I really donít care about I only give these numbers for reference) great on the bottom but lacking in top end and hotter than ever in the cruise area, saw 289ET after I left.
Does anybody here know engines and read PowerVision that could look at my background features in the map and see if thereís something that stands out? Timing should be Tits! AFRís are questionable. Seems like something is just not right. Shouldnít be running this hot cruising on the freeway.
Not looking for advice on changing engine parts. This is a build thatís been proven,multiple times, to make 125+hp 125+tq and run cool with a good tune. Iím thinking the first guy adding the piggyback made a PV switch change and the second tuner used the same base map to tune off of so he couldnít get things right either. Any help would be greatly appreciated.
PM email and Iíll send maps out. Thanks.
post #3 of 30 (permalink) Old 08-28-2018, 05:35 PM
Bruce00's Avatar
I have nothing to add, except Good Luck getting your issues dialed in.
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #4 of 30 (permalink) Old 08-28-2018, 05:45 PM
lil chief's Avatar
Those temps don't seem to crazy, especially in hot weather and in a high altitude like Jackson Hole.
What temperature range are you seeking?
Lil Chief
RGKen likes this.
lil chief is offline
post #5 of 30 (permalink) Old 08-28-2018, 05:52 PM
The Volusianator's Avatar
Those temps are not hot at all, your fine
The Volusianator is offline
post #6 of 30 (permalink) Old 08-28-2018, 06:36 PM Thread Starter
I donít want to see more than 260 cruising.
post #7 of 30 (permalink) Old 08-28-2018, 06:49 PM
HellInABucket's Avatar
Lil Chief
This is what happens when you buy a tool that measures things. You start freaking out and obsessing about things you otherwise would not have known to obsess about. Great example is Road King owners. You never see threads (well, on hdforums anyway) from them about oil pressure.
RGKen likes this.
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #8 of 30 (permalink) Old 08-28-2018, 06:59 PM Thread Starter
FYI I donít obsess over gauges. I donít leave the vision on the bike. I donít even have volt meter. Replaced with speakers. I donít give two shits about gauges. Doesnít mean the bike isnít running too hot. I typed the ďcondensedĒ story. Thanks for your help though.
post #9 of 30 (permalink) Old 08-28-2018, 07:24 PM
Wow, crabby are we?
2018 FLTRU
post #10 of 30 (permalink) Old 08-28-2018, 07:42 PM Thread Starter
Wow, crabby are we?
That would be an accurate description of my current mood. Youíre 0-1
SE 204 Cam Powervision tune kiohio Map Section 7 12-26-2014 07:11 AM
Powervision problem deadwood1584 ECM/Fuel Management systems 11 08-16-2013 01:21 PM
Powervision trip/fuel gauges issue baldwookie ECM/Fuel Management systems 0 07-04-2013 03:11 PM
PowerVision - Do you Scale or Cap? rageglide ECM/Fuel Management systems 5 06-19-2013 12:29 AM
Powervision Users smitty ECM/Fuel Management systems 9 07-20-2012 10:30 PM
