Codes p01511, p01514, P02105 - Road Glide Forums
post #1 of 18 (permalink) Old 08-28-2018, 12:40 PM Thread Starter
Help!!!!!!! having all kinds of throttle by wire issues. I replaced the twist grip sensor, throttle body cleaned the pins on the connector going to the throttle body as well as the pins on the ECU. I inspected all wiring and took the motorcycle to the dealer. They are stumped. Even after all this troubleshooting and part replacements i still get these codes and it goes into limp in mode. Only thing left is the ECU. If i replace the ECU with a used one out of the same style motorcycle how does this work? Do new ones need to be set up by the dealer? I am tired of not being comfortable on my motorcycle fearing it will break
Slider1156 is offline
post #2 of 18 (permalink) Old 08-28-2018, 01:17 PM
NickyNuts's Avatar
What year is your bike and have you found out what the codes mean?
NickyNuts is offline
post #3 of 18 (permalink) Old 08-28-2018, 01:37 PM
Cruisin1966's Avatar
P1511 EFI Power Management Mode
P1514 Air Flow Fault
P2105 EFI Forced engine shutdown
I know you're not running a TMAX, but this might help track down the codes:
http://www.thunder-max.com/techdocs/HarleyDiagCodes.pdf
2018 Black Earth/Vivid Black CVO Road Glide
1999 Deep Turquoise/Ancient White Heritage Springer
Cruisin1966 is offline
post #4 of 18 (permalink) Old 08-28-2018, 02:12 PM Thread Starter
its a 2013 FLTRU 91,000 miles. I know what the codes are just cannot figure out what to do next. The only thing left is the ECM. I have replaced, inspected and looked at everything else.
That's my main question. Can I put a used one ECM and have it work with no issues or do i have to go to the dealer and let them install a new one. Any one have an idea?
post #5 of 18 (permalink) Old 08-28-2018, 03:00 PM
FDR's RGC's Avatar
The wires going into the throttle body at the bend are known for causing your problem. Pulling on one at a time to make sure they're good. Had those codes myself and that's what I found. They looked fine but had one broken.
FDR's RGC is offline
post #6 of 18 (permalink) Old 08-28-2018, 03:59 PM
Thermodyne's Avatar
Your next step is a) buy a electrical service manual and diagnose it properly. Or b) take it to a shop.
Thermodyne is offline
post #7 of 18 (permalink) Old 08-28-2018, 06:17 PM Thread Starter
Done that. Dealer had it for 3 days. Could not duplicate. Good thing they only charged me a shop fee of 10.00. He rode it for 3 hours. Their thought it's the Ecm going out.
post #8 of 18 (permalink) Old 08-28-2018, 06:39 PM
MightyWhitey's Avatar
What exactly is it doing? Just shows codes and immediately goes into derate?
MightyWhitey is offline
post #9 of 18 (permalink) Old 08-28-2018, 06:43 PM
Did you just swap bars or have the tbw connector de pinned for anything? Did you replace with the SE tbw sensor when you replaced it? Never mind. I re-read your posts.
post #10 of 18 (permalink) Old 08-28-2018, 06:44 PM Thread Starter
Check engine light, loose throttle. Turn it off, turn it back on all works
How to Find your Diagnostic Trouble Codes ironmark Troubleshooting for Road Glides 42 05-03-2019 06:43 AM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 12:56 PM
Harley Paint Codes Wooden Nickel Road Glide Specific Discussions 11 12-19-2010 06:57 PM
Road glide error codes beachbum Troubleshooting for Road Glides 3 10-10-2010 12:56 PM
tbl codes swampfox Troubleshooting for Road Glides 1 08-23-2010 05:20 AM
