Anybody suggest a base map - Road Glide Forums
post #1 of 3 (permalink) Old 06-16-2013, 10:17 PM Thread Starter
ammojeff's Avatar
Just completed stage 1 this afternoon
Screamin Eagle Pro Tuner
Screaming Eagle Pro Air Cleaner
CFR Slip ons
Vance and Hines Dreser Dual Headpipes.
Plan to have cams done later and dyno'd but need a starting point.
I have the program but don't see a match to my configuration that I can recognize.
AMMO: Giving the enemy the opportunity to die for their country
ammojeff is offline
post #2 of 3 (permalink) Old 06-17-2013, 10:24 AM
Scoop's Avatar
I don't know what engine you have or if any other mods were done, but, I'd look for anything that has the same engine size with "Race Exhaust" and SE air cleaner/breather setup as a starting point. Just make very sure that all parameters are as you would like them, i.e.: Heat Manangement "on"; Rev limit reasonable; ACR (automatic compression release) "on" if applicable. My Dealer tune had my rev limit at 7000 rpm and my heat management "off".
Have fun, I know I did, and it's running better, cooler and with great fuel economy now. 45-47 mpg
Scoop
2011 FLTRU Fullsac Sportpipe, SE Breather/air cleaner, SEPRT Smart-tune, Corbin, Madstad 13", Gold Top Fork Emulators & Springs & JRI B shocks. 2003 XLHS
Scoop is offline
post #3 of 3 (permalink) Old 06-17-2013, 10:43 AM Thread Starter
ammojeff's Avatar
Scoop
Sweet that is the clarification I needed. BTW its a 103. I want to learn this stuff. Tried a few years ago on my softail 88 with a Thunder max and I could never dial it in.
ammojeff is offline
15 RG A base model as base can be..... maddmoe Audio 9 03-15-2015 07:30 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
What base map should I start with? fragmentum ECM/Fuel Management systems 0 02-17-2014 07:58 AM
PC-V Base Map needed Hullhorr Map Section 0 10-22-2012 01:20 PM
Base map for SERT Too Short Intake and Exhaust 0 07-23-2012 07:40 AM
