M8 107 fp3 & se447 - Road Glide Forums
  • 1 Post By Murderwon
post #1 of 9 (permalink) Old 09-15-2018, 05:39 PM Thread Starter
M8 107 fp3 & se447
Ok, so I just had the stage 2 installed but I don’t see the Harley Davidson SE447 in the drop down for my FP3. Does anyone the Cam I can use or the values to enter manually? Any help would be greatly appreciated!
Murderwon is offline
post #2 of 9 (permalink) Old 09-21-2018, 09:38 PM Thread Starter
Called Vance and Hines...they helped me download a map. Bike is purring!!!!
post #3 of 9 (permalink) Old 09-21-2018, 10:27 PM
rydin2's Avatar
Awesome! The Harley map they put in with the stage II ran like crap for me, but two Smart Tune runs with the HD tuner has me grinning every time I back out of the throttle....
rydin2 is offline
post #4 of 9 (permalink) Old 09-22-2018, 06:10 AM
JacktheBagger's Avatar
There should be an area in the cams where you can enter the open and close values of the valves for those not listed , my fp3 has it ..
2011 Ultra
JacktheBagger is offline
post #5 of 9 (permalink) Old 09-30-2018, 10:11 PM
Fillbert's Avatar
SE447 cam with SEPST runs great for me. I did two or three ďautoĒ tunes and upped the VE cells that otherwise appeared as dips in graphic mode. It runs sweet and hot, but not the best mpg. But never had great mpg even as stock. Always mid-to-high 30s. But I do like to accelerate.
Fillbert is offline
post #6 of 9 (permalink) Old 09-30-2018, 10:24 PM Thread Starter
Originally Posted by Fillbert View Post
SE447 cams with SEPST run great for me. I did two or three ďautoĒ tunes and upped the VE cells that otherwise appeared as dips in graphic mode. It runs sweet and hot, but not the best mpg. But never had great mpg even as stock. Always mid-to-high 30s. But I do like to accelerate.
Good to know... my mpg dropped from 40 mpg to 34ish not too much worried about it. Iím good with 30+. I figured it dropped more because I keep whaleing the hell out of it to hear those pipes roar
Little Wing likes this.
post #7 of 9 (permalink) Old 09-30-2018, 10:42 PM
Agreed. Call V&H and they will give you a map. I'd also look at other features like the throttle control. I have mine on medium and it really opens up the responsiveness. But you'll have to find out what works for you.
wilsonburger is offline
post #8 of 9 (permalink) Old 10-01-2018, 07:12 AM
Swomack's Avatar
Same for me
It was like a whole different bike when I changed the throttle response
The V&H FP-3 is the greatest thing going IMO
Swomack
My Gallery / Click Below Link
Swomack is offline
post #9 of 9 (permalink) Old 10-01-2018, 11:40 AM
Loss of mpg while tuning is common. The tuner is overcompensating for fuel until everything gets dialed in and you put a few more miles on the bike. You'll notice that the MPG should start going back up and return to normal after running a few tanks of gas.
Thanks for the post and enjoy!!!
RoadglideinMO is offline
Does an FP3 void your M8 warranty? bless0 Aftermarket Accessories 34 01-20-2018 11:46 PM
2017, M8 107", Wood WM8-22X cam, Jackpot head pipe & mufflers fuelmoto Dyno Results 2 11-02-2017 09:27 PM
2017 Road Glide 107 M8 Wood WM8-777 cam fuelmoto Dyno Results 5 08-15-2017 11:57 PM
2017 Road Glide 107 M8 Wood WM8-222 cam fuelmoto Dyno Results 12 12-13-2016 07:53 PM
V&H FP3 Value Bundle & Fuel Moto package deals fuelmoto Fuel Moto 0 04-10-2015 11:50 AM
