Fuelpak - Road Glide Forums
post #1 of 7 (permalink) Old 12-16-2010, 03:24 PM Thread Starter
edsglide's Avatar
Fuelpak
Pros and cons for v/h fuelpak. Anybody
edsglide is offline
post #2 of 7 (permalink) Old 12-16-2010, 03:56 PM
It is what it is meaning you look up the basic items you install such as a air cleaner, pipes, and or H-D stage 1 upgrade. They supply you with a set of numbers to enter at each setting I believe it 20 and thats it. Nothing else you can change other then that, you can monkey with the numbers but not much else and no one knows what that means except V&H. I have one on my bike and it works but if you plan on doing anything other then what has been mentioned above your wasting your money.....IMHO
twowheel99 is offline
post #3 of 7 (permalink) Old 12-16-2010, 04:17 PM
SafetyMan's Avatar
Pros:
User-friendly plug-n-play install.
V&H website to get your numbers from, easy.
Simple Stage 1 for every day use.
Economical.
Cons:
NOT fine-tuneable.
May or may not be a great fit for YOUR applicaton.
ZERO data collection.
I have the FuelPak on my OL's 09 Deluxe. Went with Rush 1.75 slip ons, SE/AC, K&N Filter. Works real well, and I'm not worried about being too lean.
I went with the TTS MasterTune on my '11 RGU, because I wanted to be able to collect data and do a fine dyno tune int he future.
.....that and I like to tinker.
Hope this helps.
WSFFWS
2B1ASK1
SafetyMan is offline
post #4 of 7 (permalink) Old 12-16-2010, 06:09 PM
BDMastiff's Avatar
Originally Posted by SafetyMan View Post
Pros:
Economical.
Cons:
NOT fine-tuneable.
Hope this helps.
What he said.
1996 Fatboy
BDMastiff is offline
post #5 of 7 (permalink) Old 12-16-2010, 07:29 PM
Originally Posted by BDMastiff View Post
What he said.
Ditto for me too.
Fatboy is offline
post #6 of 7 (permalink) Old 02-11-2011, 04:08 PM
LuckySOT's Avatar
Fuel Pak
I had one on my 2009 Ultra and it worked fine on long flat rides, but anytime I was riding in the hills or places with step grades, it sucked big time. On my 11 Glide custom I am installing the PCV with Auto Tune. I wouldn't waste ur money on Fuel Pak.
__________________________________
Thanks,
Lucky
SFFS
LuckySOT is offline
post #7 of 7 (permalink) Old 02-11-2011, 06:41 PM
joke's Avatar
I've got one, easy set up, no problems so far. Some decel/shifting popping if I don't let up on the gas. Coupled mine with the Xied O2 sensor wiring and it definately lowered my engine heat. Runs strong but I'm a flat lander; going to Colorado in August with a new oil temp gage and then I'll know fer sure. Bought mine used as a combo package with the V&H MO Muffs off someone on the HDForum for $350.
2009 Mirage Orange
joke is offline
Fuelpak...new map! READ ilmanzo31 Intake and Exhaust 7 04-03-2012 07:46 AM
Fuelpak 61009 Boogitybob Classifieds Archive (3 months old+) 2 10-09-2011 01:18 AM
Fuelpak 61019 For Sale roadog28 Classifieds Archive (3 months old+) 1 07-17-2011 05:14 PM
new model fuelpak Boogitybob ECM/Fuel Management systems 6 04-24-2011 12:10 PM
Stock ECU & VH Fuelpak vs T-Max Autotune DAK47 ECM/Fuel Management systems 3 12-03-2010 09:48 PM
