FP3 and Coolflow Fan - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 11-24-2018, 08:46 AM Thread Starter
craigffb's Avatar
I though I read that when you flash the PCM with a FP3 it eliminates the flash for the Coolflow Fan. Has anyone run across this that can confirm. I can't seem to find the info again.
craigffb is offline
post #2 of 14 (permalink) Old 11-24-2018, 09:19 AM
I'm also interested in this. I also read it'll affect the Fans Assisted Oil Cooler.
2018 Road Glide Special Wicked Red SVT BoneShaker Exhaust, RCX Tormentor Headers, FP3, Vance & Hines VO2 Naked Air Intake, AIMS Light Force Slave Cylinder, Legends REVO-A Shocks
aviscomi is offline
post #3 of 14 (permalink) Old 11-24-2018, 10:10 AM Thread Starter
craigffb's Avatar
Dang now that you say that, maybe it was the Fan Assisted Oil Cooler I read about too. Do you remember where you saw it?
craigffb is offline
post #4 of 14 (permalink) Old 11-24-2018, 10:19 AM Thread Starter
craigffb's Avatar
I found where I read it....it was the Fan Assisted Oil Cooler. Can't find anything about the Coolflow fan.
craigffb is offline
post #5 of 14 (permalink) Old 11-25-2018, 03:23 PM
Livewire's Avatar
Where did you read that? I am going to be installing the fan assisted oil cooler and am running the fp3. Searched for it on here and I must be missing the topic.
Sent from my XT1635-01 using Tapatalk
If it is stupid but it works, It ain't stupid...
2017 RGS Laguna Orange
Livewire is offline
post #6 of 14 (permalink) Old 11-25-2018, 03:42 PM Thread Starter
craigffb's Avatar
Itís not on here. HDForums.
craigffb is offline
post #7 of 14 (permalink) Old 11-26-2018, 06:46 AM
I'm not sure why a Fuel Pack 3 would interfere with the Fan Assisted Oil Cooler. The Oil Cooler fan is turned on through Digital Tech at a Harley shop and the FP3 plugs into the DTC port and stays connected. It doesn't really "flash" the ECM.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #8 of 14 (permalink) Old 11-26-2018, 07:04 AM
Not quite correct...The FP3 does flash the ECM and does NOT have to stay connected to the port. People choose to keep it connected to use some of the monitoring features.
ChromeSpark, Livewire and craigffb like this.
aviscomi is offline
post #9 of 14 (permalink) Old 11-27-2018, 10:53 AM Thread Starter
craigffb's Avatar
Got this from V&H:
If you have had the FP3 installed prior to the Digital Tech flash, below is what you would need to do. If you will be installing the FP3 for the first time after the digital tech flash, then yes it will carry over.
1. After DT flash, connect the FP3 and open app
2. Go to Customer Support and press Upload ECU Content (not the regular upload button)
3. Contact us either by phone or email (you can reply to this email with your VIN) and do not use the FP3 further until you hear back.
crazy4ink likes this.
craigffb is offline
post #10 of 14 (permalink) Old 12-28-2018, 09:51 AM
ER.RN's Avatar
I can confirm that if you add the CoolFlow fan and refresh the FP3 it will remove the DT download for the fan. My dealer was not aware of this happening and contacted V&H. I understand that there is a fix of some sort out there though.
ER.RN is offline
Harley Coolflow fan with Advanblack Air Diflector Swoop76 Paint & Bodywork Section 8 05-26-2019 07:37 AM
CoolFlow Fan dykas *General Road Glide Discussions/Pictures 12 02-23-2019 03:49 PM
HD Coolflow now available for Pre-M8 bikes! macabra11 Engine Related 24 09-27-2018 07:18 AM
17- 18 HD Coolflow Fan mcfyiup Parts for Sale 12 07-26-2018 03:06 PM
Coolflow on 14-16 Sgt Goody *General Road Glide Discussions/Pictures 6 04-18-2018 12:29 PM
