Click noise - Road Glide Forums
 5Likes
  • 1 Post By madmat
  • 1 Post By 08Zinc
  • 2 Post By RGKen
  • 1 Post By skratch
post #1 of 6 (permalink) Old 01-02-2019, 03:32 PM Thread Starter
Still Grumpy's Avatar
Click noise
Ever since a Stage 2 upgrade in December I am getting a rather loud click noise coming from what seems to be the throttle body, just behind the air cleaner.
Maybe this is normal ? I never had the SE heavy breather on my bikes so maybe that click noise was always there but now its more obvious...
Its a one time click that happens as soon as I turn on the ignition...
Is it the fuel pump turning on ?
Any one has experienced this ?
thanks -
Still Grumpy is offline
post #2 of 6 (permalink) Old 01-02-2019, 04:01 PM
madmat's Avatar
I have had bikes with low restriction air cleaners and the sound of the throttle plate was very loud, in my case it took a little getting used too. I am not sure if this is your issue but it could be.
08Zinc likes this.
18 RGS Bonneville Salt Pearl
madmat is offline
post #3 of 6 (permalink) Old 01-02-2019, 05:36 PM
08Zinc's Avatar
^^^^^^^Agree with Matt.
madmat likes this.
Blessings, Zinc -
08Zinc is offline
post #4 of 6 (permalink) Old 01-02-2019, 05:39 PM
RGKen's Avatar
thanks -
Yes it is the fuel pump from what you just described and it is normal. It's amazing what we start hearing once we do mods.
madmat and ALMOONEY like this.
2018 FLTRXS
RGKen is online now
post #5 of 6 (permalink) Old 01-03-2019, 08:45 PM
skratch's Avatar
either the fuel pump or the automatic compression releases. my acrs do a pretty loud click, while the fuel pump clicks then whirs.
reds4 likes this.
skratch is online now
post #6 of 6 (permalink) Old 01-13-2019, 11:20 AM
Had the same thing when I added a tuner, freaked me out - finally figured out it was the ACRís. I turned it off in the tuner settings (just to test, donít leave it off) and it went away.
Hession is offline
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 05:23 AM
Compensator Click OldNerdGuy Engine Related 4 07-27-2014 07:18 PM
chirping noise on deceleration cballjr54 Troubleshooting for Road Glides 13 10-21-2010 07:46 PM
New upgrades, new noise ? dhhen Troubleshooting for Road Glides 5 07-25-2010 09:00 AM
Front Fork Clunking Noise joke *General Road Glide Discussions/Pictures 12 05-01-2010 08:22 AM
