stage 1 map -- MGS / big sucker - Road Glide Forums
post #1 of 7 (permalink) Old 06-18-2013, 03:17 AM Thread Starter
bikerglasses's Avatar
stage 1 map -- MGS / big sucker suggestion..
Looking for a map other then the default map from MGS. Anyone have one they use and recommend?
Been running mine for 6/7 months and bike just feels like there could be more there. Also have some a pop from 2nd to 3rd ..not always, but sometimes.
Have 2013 103", MGS True Duals, and Ness Big Sucker, and pcV.
Thanks.
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
post #2 of 7 (permalink) Old 08-01-2013, 07:16 PM Thread Starter
Just had bike dyno'ed. Take a look at the difference between a canned map and a dyno tuned map.
post #3 of 7 (permalink) Old 08-11-2013, 02:53 PM
Crzylgzz's Avatar
I also have the MGS TD setup, with an Arlen Ness stage 1 element attached. im currently using the SERT and although I haven't come across any significant issues, I also notice a slight pop on the upshift from 2-3. but youre right, there is the sensation of lacking ,, she runs smooth, but it feels like shes starving and needs to break loose..
im considering the auto tuner, but im not sure how that thing works, everyone says its easy but so were the reviews about the PCV and man, trying to tune a bike with that thing, I need a phd in engineering..
Crzylgzz is offline
post #4 of 7 (permalink) Old 08-11-2013, 03:36 PM Thread Starter
I had auto tune and sold it.. decided its not worth the hassle and got a dyno tune.
post #5 of 7 (permalink) Old 08-12-2013, 10:35 PM
The torque smoothed out nicely in the low range. You must notice that while cruising?
I got my mgs and powervision a few weeks ago. Great pipes. Any idea what the tuner had to do to get those numbers?
McSlothy is offline
post #6 of 7 (permalink) Old 08-12-2013, 11:59 PM
Xaran's Avatar
Try calling MGS they tune with PCV and PV they may be able to send you a canned map. Or if you got the tuner from from Fuel Moto they will have one or work with you to get one.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #7 of 7 (permalink) Old 08-13-2013, 12:02 AM
Xaran's Avatar
For 4 hp and 4 tq I dont think 300 -400 on a dyno is worth doing. Ill bet with a PV and some data runs it would be even closer and less difference.
Xaran
Previous HDs
Xaran is offline
Arlen Ness Stage 2 Big Sucker Air Cleaner Kit For Harley Touring redbaron Parts for Sale 6 04-19-2014 07:33 AM
Stage I Done!!! CFRs, Cobra and AN Big Sucker Ernster500 Intake and Exhaust 24 05-17-2012 10:39 PM
Arlen Ness Big Sucker RoadGlideRider Intake and Exhaust 13 10-16-2011 07:29 PM
Is it ok to run Ness Stage II sucker without tuner or reflash DED HD Intake and Exhaust 17 08-04-2010 02:36 PM
Power Commander V and Big Sucker Air Cleaner The Infamous Sharknose Equipment-RG 0 09-18-2009 10:07 AM
