SEPST with aftermarket Stg 2 cams - Road Glide Forums
post #1 of 3 (permalink) Old 01-19-2019, 09:33 PM Thread Starter
DeneFLTRX's Avatar
Not really into voiding my warranty but always dreaming.
I have a new bike with Stage 1 and the supplied SEPST tuner.
Next season I was wondering how it would perform if I threw in an Andrews or similar cam like a Wood22x? These cams are close to the genuine HD tq cam that comes in their kit, but how would an aftermarket one run after I flashed theECM with the HD map?
2019 FLTRX, Fin
DeneFLTRX is offline
post #2 of 3 (permalink) Old 01-20-2019, 04:02 AM
RGKen's Avatar
Wouldn't work very well at all. Just get a Power Vision, Thunder Max or TTS Master Tune and make your bike run right with the cam you choose. If you are certain that the cam upgrade is all you will ever do then you might get away with the Vance & Hines Fuel Pack but you will have more control with the ones I previously listed. Especially if you do a large bore kit and head work later on. Either way the HD Street Tuner is very limited and only works with the SE setups. You can thank the EPA for that one.
2018 FLTRXS
RGKen is offline
post #3 of 3 (permalink) Old 01-20-2019, 10:47 AM Thread Starter
DeneFLTRX's Avatar
I was just thinking outside the box.
I have a married PV from my previous bike so it would be $200 for a second license, and there is nobody who uses it in these parts so if I spent the big bucks again, Id go back to the more popular TTS.
The bike is unreal with the SEPST, light years smoother than a Twinkie/PV2. Im just one to want to fiddle with perfection.
Just wondering if it would work and be safe to operate with an aftermarket stick and SEPST.
2019 FLTRX, Fin
Recommended applications for S&S Cams SMOKENJOE Engine Related 14 11-04-2017 03:28 PM
Tman Torqster 555 cams Jrod95 Sold 11 03-26-2016 11:31 AM
Is there a better combination? Wood Cams and D&D (performance baffle) Short Time Dyno Results 42 03-20-2015 10:18 AM
S&S 551 cams ShitHouseRat Engine Related 9 07-24-2013 04:47 AM
? for you guys who have changed cams Dandy1 Engine Related 28 01-17-2012 06:32 AM
