Power Vision - Road Glide Forums
 21Likes
post #1 of 41 (permalink) Old 02-14-2019, 10:50 AM Thread Starter
Power Vision
Just purchased a Dynojet Power Vision off FM. Any secrets or advice ? Just running Stage 1 at this time.
post #2 of 41 (permalink) Old 02-14-2019, 11:28 AM
RGKen's Avatar
Buy a 107" Thumper kit and throw it on the bike. Then ride it like you stole it. I mean hey... you already have a tuner so you might as well.
2018 FLTRXS
RGKen is online now
post #3 of 41 (permalink) Old 02-14-2019, 11:39 AM Thread Starter
Almost very happy with the 96. If I wanted fast ,I'd go inline 4.
Road dawg and RGKen like this.
post #4 of 41 (permalink) Old 02-18-2019, 08:54 AM
gsbuick65's Avatar
I just went thru the preloaded maps and installed one
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals, s&s 570 cams, Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
gsbuick65 is offline
post #5 of 41 (permalink) Old 02-18-2019, 09:09 AM Thread Starter
So FM loads more than one for you ? Do they explain the difference between the maps ?
post #6 of 41 (permalink) Old 02-18-2019, 09:33 AM
gsbuick65's Avatar
naw dynojet has some preloaded maps on it, you'll just have to play around with them, but they state what each is for but you have to click on it cause its just a number on the display, theres one for stock with stage one ac-performance and economy.
post #7 of 41 (permalink) Old 02-25-2019, 09:46 AM Thread Starter
Installed the Fuel Moro map over the weekend. I was very impressed on the change. Bike runs a good bit stronger and way cooler ,which is why I really wanted a tune in the first place.
Now the question is.... Should I mess with perfection and run the Auto tune basic or just leave well enough alone ? Can auto tune actually make the map worse ? Any input is appreciated.
post #8 of 41 (permalink) Old 02-25-2019, 10:24 AM
At least a couple of autotune rides are welcome to fit the map to your bike. Personally I would suggest to find a solitary road and make some runs in 5th gear from 1700 to 5000rpm with slow acceleration and deceleration (itís a lot of speed, I know) to cover most of the load conditions.
Slamming the throttle in autotune does not help a lot.
Once these 2 are done, then make a third in a winding road, riding your usual way, to fine tune the results.
When in autotune the bike runs a little rough because it mess up the spark advance a little to make its calculation, fuel consumption increase as well under this condition.
Beaver is offline
post #9 of 41 (permalink) Old 02-25-2019, 10:51 AM
smitty901's Avatar
Please tell me you purchased it from Fuel Moto so you get their free support and maps. If not then pick a tune from the canned maps loaded that is close to yours and run auto tune. You fiuge out how to use with with a few runs. Make a copy of you current tune and save it on your computer. You can also then run auto tune off that . But save a copy just in case .
Hammerhandle likes this.
smitty901 is offline
post #10 of 41 (permalink) Old 02-25-2019, 10:57 AM Thread Starter
Of course I bought it off Fuel Moto. They loaded an assume map for my bike too.
Power Vision & Power Core- Have You Ever ? Arkie ECM/Fuel Management systems 0 10-16-2018 12:26 PM
power vision find RT Green screen Arkie Map Section 2 10-01-2018 07:15 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Two power vision questions bikerbehaviorist ECM/Fuel Management systems 9 03-30-2014 01:03 PM
Power Vision Question Teagatron3000 ECM/Fuel Management systems 5 04-06-2013 05:28 PM
