Warranty ended!
Time to finish the stage I on my '17 RGS. So I called Fuel Moto and they fixed me up with a PV with a preloaded map. It took me 5 min to flash my ECU using this. Will play with autotune later.
As far as the AC goes, the Arlen Ness "Big Sucker " that I bought from FM is huge, and well made. Be warned, the install instructions suck, but install is pretty easy once you figure out what the parts are. Be sure to have grease and blue Loctite handy.
The bike is running great. The reason I went ahead and did this was to cool the engine down. I felt that is was running too lean stock, especially since I added slip ons. We shall see how that works out.
2017 HD Road Glide Special
Sponsored Links | |||
Originally Posted by jcarruth
View Post
A.K.A OBB
Originally Posted by Ohiobellboy
View Post
Slips on won't change how the bike runs very much as far as lean/rich conditions unless the cat is removed from the headpipe. That's where the exhaust flow is controlled.
2018 FLTRXS
Originally Posted by RGKen
View Post
Believe it or not but the slip-ons will have more to do with the flow than the CATS. The CATS do not affect the flow as much as you would think. That's why you can gut the CATS and not have to re-tune but if you change slip-ons and A/C you need to re-tune.
View Post
Originally Posted by Buzzy
View Post
Does that mean on my 103, I can decat and use stock or cvo slip on's and stock A.C., not tune and get a cooler leg?
2018 FLTRXS
View Post
Originally Posted by SteadyEddie
View Post
You mean added THE ULTIMATE IN BAD ASS SLIP ONS....said in a thunderous, god like voice
Thread Tools | |
Display Modes | |
Similar Threads | ||||
FWIW: M8 Warranty & Fines | DOOFUS | ECM/Fuel Management systems | 60 | 03-26-2017 02:58 PM |
Warranty almost up - getting nervous... | Methos1979 | *General Road Glide Discussions/Pictures | 35 | 09-01-2014 11:38 AM |
Failed rings...extended warranty may not cover? | pastryslayer | Engine Related | 21 | 05-26-2014 10:29 PM |
Tire and wheel warranty, hmmmm | bvanlente | Wheels and Tires | 14 | 09-18-2012 12:34 AM |
Extended warranty question... | Johnzz1420 | *General Road Glide Discussions/Pictures | 4 | 07-12-2012 10:39 AM |
Posting Rules | |
