Air cleaner??? - Road Glide Forums
post #1 of 2 (permalink) Old 03-11-2019, 09:52 PM Thread Starter
Air cleaner???
For those of you running larger engines, what air cleaners are you using with the larger throttle body's? I'm going to be using the SE 58mm throttle body and the SE stage1 air cleaner that I was using on my stock throttle body is way smaller in diameter than the 58mm throttle body. Is there an air cleaner that I can use that's the same diameter as the 58mm t-body?
post #2 of 2 (permalink) Old 03-11-2019, 11:06 PM
I’ve held my stock ‘18 throttlebody up against the stage 4 64mm throttlebody and the bolt pattern is the same. If that helps at all
2018 FLTRXS Wicked Red
Harley Master Tech at Hampton Roads Harley in Yorktown, VA
crazy4ink is offline
HD Heavy Breather Air Cleaner Kit + Extras! Rockitman Parts for Sale 0 07-29-2018 07:19 PM
Screamin' Eagle Chisel Air Cleaner Issue Gregfry ECM/Fuel Management systems 10 02-23-2017 04:25 PM
Air cleaner first ? Chrisjer Intake and Exhaust 52 01-11-2016 08:56 AM
Screamin' Eagle Stage 1 Air cleaner (matte black backing plate) rsscoggins Parts for Sale 2 04-13-2015 12:59 PM
Stage 1 Air Cleaner cvanmete Parts for Sale 3 10-31-2013 11:07 AM
