FP3 idle - Road Glide Forums
 15Likes
  • 1 Post By JacktheBagger
  • 3 Post By JacktheBagger
  • 4 Post By RGKen
  • 1 Post By wevsspot
  • 1 Post By RGKen
  • 2 Post By JacktheBagger
post #1 of 10 (permalink) Old 03-26-2019, 07:48 PM Thread Starter
Wvroadglide's Avatar
FP3 idle
Set my idle to 900rpm from 950. Sounds much more like a Harley, accelerates and runs good. Does anyone have their bike set to 850 or so. I know when the M8 came out 850 was the setting.
2019 RGS
Wvroadglide is offline
post #2 of 10 (permalink) Old 03-26-2019, 11:33 PM
JacktheBagger's Avatar
may sound good , but there is a reason FI bikes idle higher ..
rlaf75 likes this.
2011 Ultra
JacktheBagger is online now
post #3 of 10 (permalink) Old 03-27-2019, 05:14 AM Thread Starter
I wonder why that would be?
2019 RGS
post #4 of 10 (permalink) Old 03-27-2019, 05:23 AM
Charging system for one and iirc , something to do with the fi or needs the higher idle because of the fi ..
rlaf75, RGKen and Jacksprat56 like this.
2011 Ultra
post #5 of 10 (permalink) Old 03-27-2019, 06:08 AM
Can you elaborate on the specifics of your theory or is this just something you hear during a convesation somewhere?
beerhunter is online now
post #6 of 10 (permalink) Old 03-27-2019, 07:07 AM
RGKen's Avatar
Carb bikes have far fewer electrical components to provide power to so they can idle lower and still allow the charging system to keep up. It is true that when the M8 first came out it had a lower idle but there was an updated MAP that soon came out to raise the idle a bit. Never heard what the real reason was but most likely due to charging output. If I wanted to lower my idle I would do research and testing to make sure I knew how low I could go safely and not just arbitrarily change it just because I think it sounds cooler. No problem doing mods or adjustments to the bike as long as you know what the real results will be.
2018 FLTRXS
RGKen is offline
post #7 of 10 (permalink) Old 03-27-2019, 08:41 AM
wevsspot's Avatar
In addition to the charging system............
How about low oil pressure concerns? I don't know one way or another, just asking.
Jacksprat56 likes this.
wevsspot is offline
post #8 of 10 (permalink) Old 03-27-2019, 10:33 AM
RGKen's Avatar
Since these engines aren't really about pressure and are more about flow it's probably not a big enough issue at idle once the bike is warmed up. I wouldn't want my cold temp rpm setting too low. You set the idle rpms in different ranges based on engine temperature so a cold bike will idle higher until it reaches a certain temp and then steps down as it gets warmer. I know some guys that have set their hot idle at the upper temps set down around 850rpms but the oil is already flowing good at that point so it shouldn't be an issue. Going back to the electrical part though, they would need to know if the charging output is greater than the electrical draw at that rpm. I would say probably on most bikes unless you've added a lot of lights and/or amps and speakers.
wevsspot likes this.
2018 FLTRXS
RGKen is offline
post #9 of 10 (permalink) Old 03-27-2019, 03:11 PM
Been doing this for 48 years , dont repeat conversation as fact ..
2011 Ultra
post #10 of 10 (permalink) Old 03-27-2019, 03:13 PM
all the accessories on the new bikes require more from the charging system , the efi needs a certain amount of voltage to operate correctly , therefore the higher idle ..
2011 Ultra
Rich & Rough Idle gazrnr Troubleshooting for Road Glides 0 11-12-2016 07:35 AM
Help Diagnosing idle issue TYM2GLIDE *General Road Glide Discussions/Pictures 1 11-11-2016 12:57 PM
F Me High Idle Woes johnd5412 Troubleshooting for Road Glides 23 03-21-2016 07:58 AM
2010 RGC with idle issues.... need help fast jmg2001 Troubleshooting for Road Glides 4 07-27-2015 08:53 PM
Engine idle RPM? mandlbarrett Troubleshooting for Road Glides 2 07-05-2012 07:12 PM
