Im looking for some tuner advice - Road Glide Forums
 6Likes
post #1 of 14 (permalink) Old 04-12-2019, 01:21 PM Thread Starter
I'm sure I'm beating a dead horse here but I'm kinda confused. With my stock 96" motor I was using the V&H FP3 and it ran great. I was actually getting compliments on how the stock motor ran. Ok fast forward. I just did a S&S 124" motor. I got in touch with V&H to inquire about a possible preliminary MAP to use for some break in miles. I'm currently using my stock head pipe with the stock O2 sensors up by the head ports because in 09 there was not a catalytic converter in the head pipe so in my opinion it acts like a xpipe. I've got about 250 miles on the motor with that preliminary V&H FP3 Map and stock head pipe and it runs great. I do plan on getting it dynoed as I want to see the numbers it runs. My question is, in your opinions, what would be the best tuner to get the best bang for the buck? I know there's several out there. I just dont understand them that well. Thanks
post #2 of 14 (permalink) Old 04-12-2019, 01:56 PM
JacktheBagger's Avatar
S&S recommends the power vision ....
Dickie likes this.
2011 Ultra
JacktheBagger is offline
post #3 of 14 (permalink) Old 04-12-2019, 02:01 PM
Absolutely get in dyno tuned. You have spent big money getting a top tier motor. A proper tune is almost mandatory!
My opinion only. The best way to break a motor in is on the dyno. The operator has full control of this situation, no traffic to deal with, stop lights, etc.
When I assembled my motor, I put a "Ballpark tune" into my PC5 just to make sure it ran and check for leaks.. Shut it off, put it in the trailer to the tuner.
He broke the motor in and tuned it in one day. I didn't have to bring it back to get the "Final Tune".
Money well spent, it was budgeted into the build cost.
Best tuner/ The one the guy tuning it likes the best. PV, TTS are the most common along with Thundermax
Swomack and duglauraflht like this.
phillyfan1 is offline
post #4 of 14 (permalink) Old 04-14-2019, 09:17 PM
I'd talk to the guy who's doing the tuning. The tuner is only as good as the tech using it. Most commonly used are the tts master tune, and the Dynojet Power vision .
PS. If you buy the Power vision, get it from Fuel moto. They will load a decent starter map in it and double the warranty.
post #5 of 14 (permalink) Old 04-20-2019, 06:39 PM Thread Starter
Welp! Upon the advice of my tuner/dyno guy I went ahead and picked up a Thundermax tuner from Fuelmoto. I got it installed but got a little confused with the program procedures. I wound up contacting my guy and he got me through it so I was able to get the base map loaded. He recommends doing a few autotune rides so I can load the new learned values so the thundermax can fine tune it accordingly. I was only able to get in a short 20 mile or so run due to the rain I got caught in. I got back to my garage and applied those learned values to the module. Hopefully the weather clears up a lil so I can get back out and ride some more. I will say though, the initial map and that short run I was able to make, I did notice some differences. So far I'm very pleased with the thundermax
James likes this.
post #6 of 14 (permalink) Old 04-20-2019, 08:26 PM
You were able to use that tuner with your stock 02 sensors too , right ?
post #7 of 14 (permalink) Old 04-20-2019, 10:52 PM Thread Starter
The thundermax comes with wide band O2 sensor that need to be used
post #8 of 14 (permalink) Old 04-21-2019, 08:56 AM
I thought I heard the 09 had the wide band o2 sensors ?
post #9 of 14 (permalink) Old 04-21-2019, 09:45 AM
Thermodyne's Avatar
Big holes, narrow sensors.
rlaf75 likes this.
Thermodyne is offline
post #10 of 14 (permalink) Old 04-21-2019, 09:50 AM
Thermodyne's Avatar
The Thundermax is a good tuner. But no dyno guy is ever going to recommend one, no money in it for them. They got dynos that need paying for or leases with years left to run, they are going to sell you a tuner that requires a dyno.
I make 125+ with a Tmax on a 110 with fairley mild cams (SS585) That's as good as I've seen from any dyno tuned pulls.
Seeking advice / help with getting a tuner Blueangel73 ECM/Fuel Management systems 29 12-10-2018 01:53 AM
Tuner advice conn-e-rot ECM/Fuel Management systems 14 03-09-2017 04:54 PM
Tuner advice needed palmpalm ECM/Fuel Management systems 19 09-01-2016 12:17 PM
advice for tuner bruce hurt ECM/Fuel Management systems 9 02-04-2015 09:47 PM
Fuel Moto Micro EFI Tuner install and review Garemlin ECM/Fuel Management systems 21 06-28-2013 05:50 PM
