Catless header and FP3 on 2013FLTRU - Road Glide Forums
post #1 of 14 (permalink) Old 04-24-2019, 12:57 PM Thread Starter
sfcusaret2004's Avatar
So, I've read everything I can find about de-catting a TC motor and am getting ready to finally do my '13 ultra (Road Glide of course)! Thing is I haven't seen, heard, or read anything about what to do about the O2 sensors! I know they are upstream of the Cat, but am wondering if most folks just leave them in the head pipe or cap them off. If they are left in the pipe, will this cause an error code?
I have the FP3 and am planning on just running an autotune session after the swap, but still I'm concerned about the error codes showing up. Any thoughts from those who have done this swap before
sfcusaret2004 is offline
post #2 of 14 (permalink) Old 04-24-2019, 01:21 PM
JacktheBagger's Avatar
Mine is stock with FP3 and gutted catless header .. They sent me a map to put in , will send the info to you later ..
2011 Ultra
JacktheBagger is online now
post #3 of 14 (permalink) Old 04-24-2019, 01:47 PM
PBSTN's Avatar
I have capped them off. And I have left them in, and unplugged them in the side cover. Either is good assuming you don't need them.
2001 FLHR-Traded. 2010 FLTRX-Sold.
2010 FLHR
2003 FLHRSEI2
PBSTN is online now
post #4 of 14 (permalink) Old 04-24-2019, 02:32 PM Thread Starter
"I have capped them off. And I have left them in, and unplugged them in the side cover. Either is good assuming you don't need them."
Doesn't answer the error code question
"Mine is stock with FP3 and gutted catless header .. They sent me a map to put in , will send the info to you later .."
Was planning on this if necessary, but still doesn't answer the error code question!
Does/did your bike throw any sensor related codes when you originally did the mod?
post #5 of 14 (permalink) Old 04-24-2019, 03:55 PM
I left the sensors in , no codes thrown ..
2011 Ultra
post #6 of 14 (permalink) Old 04-24-2019, 07:35 PM
PBSTN's Avatar
No error codes here.
2010 FLHR
2003 FLHRSEI2
PBSTN is online now
post #7 of 14 (permalink) Old 04-25-2019, 08:37 AM Thread Starter
Thanks Jack, that's the answer I was looking for!
post #8 of 14 (permalink) Old 04-25-2019, 08:38 AM Thread Starter
Thanks PB, Again, that's the answer I was looking for!
post #9 of 14 (permalink) Old 04-25-2019, 04:32 PM
So you have no issues with the sensors unplugged ??? With FP3 ??
2011 Ultra
post #10 of 14 (permalink) Old 04-25-2019, 07:48 PM
PBSTN's Avatar
I have used fp3 and pc5's. With no issues.
2010 FLHR
2003 FLHRSEI2
PBSTN is online now
